Dash Guages
Discussion in 'The Garage' started by anjieandjohn, Sep 22, 2005.
  1. anjieandjohn
    anjieandjohn Registered Member
    Oct 31, 2004
    61
    Virginia Beach
    Just a question or two about the dash guages....When I start up my truck, the oil pressure guage just starts spinning....after the truck warms up, the oil guage still spins and the temp guage barely moves off of the bottom notch. Meanwhile, the volt guage reads about what I would expect it to read. I have replaced the tstat because I thought that might be the problem but it didnt change the symptoms....I have also looked at replacing the circuit board in the instrument panel as well....any suggestions? I havent replaced the oil pressure sensor yet but figured I would wait becaue the problems all seem related to each other. Also, my gas guage works sometimes and sometimes it doesnt. I havent replaced the sending unit yet again because it seems like all the problems are related. :eek1:
  2. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    did you pull the guages out, if you did check the harness going into it. mine was almost unplugged and was acting the same. :D
  3. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    Like stated disconnected harness or if not I would put my money on the printed circuit. About $90 to replace depending on year.
  4. anjieandjohn
    Oct 31, 2004
    61
    Virginia Beach
    Just went and traced out the wires for the problems I am having with the gauges and guess what.....the temp sensor is actually bad and the wire from the oil pressure sensor was broken....fixed and replace both and I am happy now...I know I have good oil pressure and my truck isnt overheating....Thanks for the help.
  5. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    err an entire cluster out of car-part.com for $25 to my door.. oh yeah had factory tach too!!!! :haha:
  6. Robert D
    Robert D 1/2 ton status
    Oct 2, 2005
    261
    Austin, TX
    How difficult a task was replacing the temp sensor? I think mine is bad as the temp guage doesn't do a thing :eek1:. In the 944 it was a PITA to replace, but what wasn't in that car :haha:.
  7. RootBreaker
    Nov 29, 2001
    5,118
    173
    depends on what motor you have...
    most 350's are on the side on the head or on the temp sensor neck..... I have one on both... but only using one :haha:
  8. Robert D
    Oct 2, 2005
    261
    Austin, TX
    Ah, I have a '91 350. So it is just bolt off bolt on? WTH I love this easy-to-work-on truck!
  9. RootBreaker
    Nov 29, 2001
    5,118
    173
    wait till people tell you that you can get parts from a bubblegum machine... best part is chevy parts are ALOT cheaper than most... I paid $25 for a starter and $25 for an alternator :haha:
  10. Robert D
    Oct 2, 2005
    261
    Austin, TX
    Geeez. You know when my father was overseas I helped the step-mom get his 911 into a shop to replace the alternator ('86 911 70k orig. miles) and it ended up being 1k to do....on the 944, luckily the alternator never went out as rebuilt units were at least 180.00. Starters were in that ballpark also....geez 25.00 I can get used to this! Also, with the ~30 dollar plug wire kits from places like summitracing, are these any good??? The wires on the 944 were about 160.00 or so for a decent set if I remember correctly :doah:.
  11. anjieandjohn
    Oct 31, 2004
    61
    Virginia Beach
    I have a lowly 305 and the temp sensor is on the driver's side of the block. I know..I know...I need to upgrade..and I am on my way....
  12. spirit
    spirit Newbie
    Nov 10, 2005
    KSA
    GMC Jimmy 1978 instrument dash Gauges
    :confused: Hi, I am having a bit of trouble finding decent gauges for my truck (complete set, RPM, Odo, Oil, Batt, Temp & fuel) do you know any links that can help? & can I fit any type of gauges and just change the back plastic plate to aluminum?
    Spirit
  13. Robert D
    Oct 2, 2005
    261
    Austin, TX
    Check out lmc parts store?
  14. RootBreaker
    Nov 29, 2001
    5,118
    173
    or if you want oem.... just goto car-part.com and do a search.. I got the factory unit with factory tach for $25 to my door :bow:
  15. spirit
    spirit Newbie
    Nov 10, 2005
    KSA
    Thanks for the info...
  16. neubanksc5
    neubanksc5 1/2 ton status
    May 13, 2005
    281
    Concord,CA
