Dash light help ASAP
Discussion in 'The Garage' started by 86haubs, Dec 29, 2005.
  1. 86haubs
    86haubs 1/2 ton status
    Nov 14, 2005
    196
    Lemoore, CA
    Going out of town this tonight and my dash lights quit woking. It used to be dim, but I would mess with the headlight switch and it would come back on. Now it is dead. I checked everything I could think of. The only lights working are the blinkers and high beams. I ruled out the chance of a light bulb because all the gauges are off. What are the chances the headlight switch could be bad?
  2. mr_clean
    mr_clean 1/2 ton status
    Sep 21, 2003
    348
    Sacramento, CA
    I'd say very good. If you fiddled with the headlight switch to get it working then it sounds like the pot on that switch is shot.
  3. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    Where is the quickest place to pick one of these up besides the dealer, are they carried at Autozone, or something similar? Do you know how much they run and about how hard the install is?
  4. theperfectgarage
    theperfectgarage 1/2 ton status
    Oct 5, 2005
    988
    tucson arizona
    auto zone,checker, napa etc. E.Z. to replace and prob. under 20.00.
  5. mr_clean
    Sep 21, 2003
    348
    Sacramento, CA
    Mine is $13 at Autozone for a 73', and they are pretty easy to change out.
  6. 86dieselburb
    86dieselburb 1/2 ton status
    Oct 20, 2004
    219
    Crestline, CA
    I just bought a new GM switch from Classic Industries. Got the GM part number. Its alot cheaper at GM Parts Direct like only $16. Was $29 at Classic
    73-78 Headlight Switch #1995217
  7. wildmouse216
    wildmouse216 1/2 ton status
    Dec 26, 2005
    135
    Rifle, Colorado
    Check your taillights. The dash lights will die if your taillights go out.
