Dash Light tie in
Discussion in 'The Garage' started by globaljames, May 23, 2006.
  1. globaljames
    globaljames Registered Member
    Apr 2, 2004
    52
    AZ. Scottsdale
    I have just installed a tach and im looking for a nice spot to hook up the light to be operated with the night dash lights and Ideas ? I have a 91 blazer old body style Thanks in advance
  2. skidpan
    skidpan 1/2 ton status
    Sep 21, 2005
    226
    SOCAL
    i just tapped into one of the wires that plugged into the back of the factory gage cluster. just traced the power source that one of the dash lights used, and tapped into that.
  3. globaljames
    Apr 2, 2004
    52
    AZ. Scottsdale
    Thanks but that doenst work so esay on a newer truck
  4. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    I tapped into the dash light lead coming off the headlight switch, i musta picked teh right one caus eit dims wth thedash lights. get a wireing diagram and figure out which ones which and tap off that.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I am not sure about the newer trucks wiring colors , but the Blazers I have worked on had a gray wire for the dimmer switch , off the headlight switch , off the stereo harness , and off the cluster harness .
    For my tach I cheated , I took the dash lps fuse out , stuck my wire against the blade and pushed it back in . Hasn't pulled out , and the tach dims with the dimmer switch :thumb:
  6. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
  7. globaljames
    Apr 2, 2004
    52
    AZ. Scottsdale
    Thanks guys And Pauly My diagram looked like the grey wire but it was a little tough to sort out. I looked at the cram and jam method but I didnt want to crack all of that circuit board looking stuff back there Thanks all
  8. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
  9. dyeager535
    26,979
    I seem to recall that one or two of the accessory terminals on the fuse panel is also run with the headlight switch, but I confess I didn't look at the wiring diagrams (linnked previous) to double check.
  10. globaljames
    Apr 2, 2004
    52
    AZ. Scottsdale
    Thanks again Pauly Looks like that piggy back is the ticket.
  11. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    fusebox tap..
    The "old style" trucks from 73-87 had a tap in the fuse box with a male spade sticking out marked "PNL LHTS" or "INS LMPS that works with the dimmer on the headlight switch,just like the dash cluster lights...I assume a 91 with the "old" style body should have it also..beats splicing into existing wires..:crazy:
