Dash Lighting Problem
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5XLR8R, Aug 29, 2000.
  1. K5XLR8R
    K5XLR8R 1/2 ton status
    Aug 22, 2000
    210
    Washington State
    I just spent two hours changing the all the dash/instrument panel lights about two weeks ago, now the bast#*ds have burnt out again...checked the fuse and it was blown...changed it and they still dont work...before i spend more time and money to change all the bulbs again..I was wondering if anyone had any ideas as to what the hell is going on...???!!!!
  2. Emmettology 101
    May 9, 2000
    8,126
    FL
    OSunds like you have a short somewhere, you will need to follow the wires and see if there is a bare wire somewhere or a wire rubbing on a metal part.
    Mike [​IMG]
    See <font color=green>EMMETT</font color=green> -&gt; http://emmett.coloradok5.com
  3. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    Double check that you are using the right size fuse, too.
  4. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    Check the wiring to the stereo. If someone took the power/ground from the first wire(s) they found they could have found the interiour lights circut. Does the fuse first blow when the ignition is turned on, and does the lights work before you do this?
    http://www.espen88k5.coloradok5.com
  5. Rayven90
    Rayven90 Registered Member
    73
    FT Lupton, CO.
    Definetly make sure you have a good ground on the panel.
    Ray
  6. BigBadBowTie
    BigBadBowTie 1/2 ton status
    Apr 6, 2000
    160
    AZ
    Had a similar problem a couple years ago. The Wiring circuit on the back of the instrument cluster was rubbing on a dash tab, it rubbed through the plastic coating and broke the connection. You can get a new circuit board, or, I had mine soldered back together, then I put some black tape over it. Bent the offending tab out of the way, all better.
    HTH
    <font color=purple>Rick
    86 K-5</font color=purple>
    http://www.BigBadBowTie.ColoradoK5.com
