Dash lights dont work
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 76_Cheyenne, Oct 21, 2002.
  1. 76_Cheyenne
    76_Cheyenne 1/2 ton status
    Jan 23, 2002
    285
    Missoula, Montana
    Ever since I bought my 76 K10 the interior gauge lights have not worked. I have checked all of the bulbs and they all are fine, I have replaced the fuse, and I know there is a printed circut behind all the gauges and I know that it costs 80$ and thats not worth the light. Am I overlooking anything here, any one have the same problem and found a solution? Thanks
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    sounds like your headlight switch, try turning it and see if that works, but it might need replacing.
  3. TIGHTWORK82 K5
    TIGHTWORK82 K5 1/2 ton status
    Oct 21, 2001
    140
    orlando , florida
    make sure you check the ground lead for the wire harness. mine was disconected when I re-installed it took me 2 more times of taking it apart to figure it out. I dont remember off hand the position # check the manual or it can be traced out to the firewall.
  4. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    I agree with Muddytazz to check the headlight switch. The rheostat inside for variance of the dash brightness will get corroded/dirty over time and cease to function.
    A second thought would be to ensure that the connector to the printed circuit is not corroded/dirty and is making good contact.
    /forums/images/graemlins/burb.gif
  5. Ck1500
    Ck1500 1/2 ton status
    Feb 8, 2001
    198
    Burton, Michigan
    mine was the ground to the fuse block was not hooked up or came loose or something . but i basically pulled all 3 of my hairs out trying to figiure it out /forums/images/graemlins/shocked.gif but its done now, and if i ever have the same issues again i am going straight for the grounds.
    hope this helps
    /forums/images/graemlins/ears.gif Ck1500
  6. Texas84K5
    Texas84K5 Registered Member
    Apr 29, 2002
    14
    Weatherford, Texas
    My 84 K5 dash lights recently went out. I changed my switch and that did not fix the problem. one twist to my problem...when I turn on my lights, the cab lights come on at about half strength and my guage lights do not turn on at all.
  7. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Look for a missing ground in the das /forums/images/graemlins/thumb.gifh.
