Dash lights
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by '73 K5, Jul 11, 2000.
  1. '73 K5
    '73 K5 1/2 ton status
    1,763
    Kansas
    When I was driving around the other night all my dash lights went out. The headlights and tail lights are still working and all the fuses are good. Any ideas what would take all of them out at once?
    '73 K5
    Chevy good...Ford bad
  2. Ryan88Jimmy
    Ryan88Jimmy Registered Member
    64
    Winnipeg, Manitoba, Canada
    try wiggling your switch around. sometimes mine does the same things and you just gotta play with it [=
    Ryan88jimmy
  3. 4x4blazer
    4x4blazer 1/2 ton status
    Jun 14, 2000
    278
    Louisiana
    I have to use the switch wiggle technique sometimes myself. Just turn the knob back and forth like you are going to dim the dash lights.(if your lights worked right, it would be kind of like making your own disco inferno on wheels, maaaan!)haha
    Anyways, a friend of mine had this prob with his '79 Scottsdale. He replaced his switch and, WALLA !, no more problem. You might try that. I am pretty sure LMC TRUCK has these switches for next to nothin. www.lmctruck.com
    Hope this helps a little.
  4. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    When the rehostat in the switch goes bad this will happen. Switch needs to be replaced.
