dash pad querey
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 4wood, Jan 2, 2004.
  1. 4wood
    4wood 1/2 ton status
    Jul 27, 2003
    116
    Atlanta, GA
    I pulled the dash pad out of my 1987 K5 to replace the front factory speakers the other day and now I am having a world of trouble getting the dash pad back on. Anyone have any advice on how to accomplish this?
  2. dyeager535
    26,976
    make sure you line up all the clips that slide into place, and that none have pulled off the pad and are stuck in place.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    have to coax it back into place, its kinda tricky
  4. camiswelding
    camiswelding 1/2 ton status
    May 25, 2003
    2,545
    Redding, CA
    my clips bent a little so I had to make sure they were reformed correctly... I ended up using some trim screws to hold it down flat.... they were the chevy ones with washers on them... it came out sano as I measured of the windshield and put them on four places on the top of the dash... its rock solid and without any squeaks now...
    cam
  5. 4wood
    Jul 27, 2003
    116
    Atlanta, GA
    what exactly do you mean by clips?
  6. camiswelding
    May 25, 2003
    2,545
    Redding, CA
    if you have the pad off and look at the underside of it you will see that there are spring clips that are molded into the urethane and fit into the sheet metal of the dash pad... these fit into corresponding shots in the metal part of the dash of your truck... sometimes a clip can move and then you cant get the dash back down flat... line the clips up with the dash holes ...put the dash on and then slide it forward slightly until the clips engage fully into their metal slots.... as I said earlier sometimes the clips get bent so they need to be flttened so that they put enough downward force on the dash when its fully in place... I also used some trim screws which really made it solid and squeak free.... if you follow my suggestion on screws as well make sure you are drilling through the pad into an area with sheet matal behind it... there are alot of open spaces below the pad underneath the pad... speaker area etc...
    good luck
    cam
