Dash POD Gauge Holder ****PICS****
Discussion in 'The Garage' started by badmix, Sep 25, 2006.
  1. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    Welp, after all the contemplating of what to do about extra gauges, short of replaceing the OEM stuff (which I will do eventually) and I didnt really wanna cut holes in my dash like the Banks article (posted in my other gauge post). So, there are only so many options.
    I started looking on Summit and Autometers site and seen some dash pods. I figured one of them would work. The 3 gauge pods look pretty big. The k5 dash really isnt that big or deep. So, I opt for the Ford Mustang Dash gauge pod. Luckily the local speedshop had the Gauge Pod and the Volt meter, the clock was special order, so ill be getting that later on in the week.
    Installation was pretty easy. There is absolutely NO DRILLING required. But you do have to loosen all the screws on the dash to raise it enuff to put the lil support bar underneth. My dash is pretty old and brittle, so I had sure to not have the bracket under the dash being totally supported by the speaker holes. Its on the edge of speaker holes and pad itself. Plus there is metal dash part around the speaker hole.
    You simply position the bracket with built in bolt thru one of the speaker holes, its a perfect fit. And for the wires, jus slide them thru the speaker holes as well. The hardest part is fishing the wires down. If you get under your dash with a light shining down, you can see the lil narrow space you have. Its between the Vent ducts and something else. I actually only had to refish one of the lines, all the others fell down enuff for me to get ahold of.
    The only real modification is to the pod itself. The one I got is for 94-2003 mustang. The dash on my '84 K5 is pretty flat for the most part. The pod has a weird shape to the bottom of it. The corners are lower than the sides. So when it sits on flat surface it looks bowed in the middle at the front and sides. This is easy fix, jus take a file or dremel and work on the corners, jus do a lil bit at a time and test fit it each time. eventually youll get it flat. The flatter it is the more OEM itll look.
    The one thing that was surprising to me was the color of the pod (the come sorta gloss black). This is a make it or break type deal. Color of the pod matters. I had some Light Blue metallic paint and figured since my truck is Blue id do that. Well it was too light and the gauges themselves (silver ultralight series) kinda got lost in the light blue. Also my dash is dark flat blue, a color that is lighter than the dash will show any impurfections in your filing , esp. on the edges.
    Next I went with Dark Glossy Blue (as in the pics). This is okay, but my dash is really dull. So, Ive gone with Semi-Flat Black. This is a pretty good color. The dullness matches my dash pretty well. The Black kinda stands out a lil bit. But the Black makes the Silver gauges easier to read. One cool thing about this type of plastic is that it doesnt take very much to paint it. Jus a few light coats and its done. If I can find some semi-flat blue, ill do that, for now, ill live with the black.
    Taking the pod off and on isnt a big deal. There is a 10mm nut in the center, you have to remove one of the gauges to get to it. The gauges fit VERY tight. When I get the Clock, if its TOO tight, I may lightly file the hole to make it a lil easier to go in and out.
    Overall im happy with it. Its a fairly easy project, jus takes time and patience like all things.
  2. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    looks good
  3. dremu
    Feb 27, 2000
    15,958
    452
    East of San Francisco
    One thing, the pic makes it look like it's twisted to the right, so your passenger could read it easier than you. Is that just a trick of the camera?
    -- A
  4. badmix
    Nov 7, 2004
    4,205
    60
    West Virginia
    Well, sorta kinda I guess. It seems the dash is kinda angled that way. I think its more of an illusion with the camera. The gauges arent hard to read, Ill see how the clock is when I get it.
  5. badmix
    Nov 7, 2004
    4,205
    60
    West Virginia
    New pics of it finished with other gauge mounted
  6. ccatlett1984
    ccatlett1984 1/2 ton status
    May 1, 2005
    161
    michigan
    the pics dont work, do you still have them by chance?
  7. lochenjons
    lochenjons 1/2 ton status
    Sep 13, 2006
    682
    Santa Cruz, CA
    x2 I dont see any pics either
  8. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    this post is 1year old...but i too want to see pics...i wouldnt mind havin a pod for the tranny temp gauges.
  9. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    I dont see not one pic
  10. danny7139
    danny7139 1/2 ton status
    Jan 27, 2005
    227
    florida
    This is the pic from badmix's install.
  11. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    :d:d :d
  12. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    Thats bada$$... What is that, Heep stuff?
  13. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    Nope, it's out af an 87 4runner.
  14. ryoken
    Jun 13, 2003
    29,623
    1,379
    Jersey Shore
    whats the one to the left?
  15. Jason4x4
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    altitude
