dash schematics. color of the fuel gauge wire
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by TorkDSR, May 11, 2003.
  1. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    78 chevy, anyone know the color of the fuel level wire from the sender at the gauge cluster... could it be solid brown by any means?
    thanks guys
    ryan
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Check out this page
    http://www.73-87.com/garage/gauges.htm
    Scroll down a bit to the wiring section...
    I used this guys wire ID when I swapped in my AutoMeters and it was spot-on...may be different on a 78 though...
    Chris
  3. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    yeah its different, hes listing colors i dont have.
    i htink i found it, but if im wrong im having illusions of blowing myself to smitherines... you know, shorting it out through the sender and igniting some fuel vapors
    but thanks
    anyone else? i cant find this anywhere
    thanks
  4. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I'm pretty sure it's pink. Yep, pink.
    -- Mike
  5. TorkDSR
    Sep 1, 2001
    1,258
    bucks co pa
    hmmm...thnaks for the help, but there is no pink one there.
  6. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Pink. There might be two wires up by the cluster depending on year and model. It was due to the possibility of having an auxilary tank.
    If you're not on dialup or if by some weird chance it's not pink you can figure out where it connects to by the picture I've got of my cluster on my webpage for my tach install. This way you can figure out which color wire it is.
    http://www.wrath.com/4x4/tach.htm
