Dashboard swap
Discussion in 'The Garage' started by rotorjockey, Feb 28, 2004.
  1. rotorjockey
    rotorjockey Registered Member
    Feb 28, 2004
    30
    Phoenix, AZ
    I have a 94 full size blazer and would like to swap out the dash with one from a 95-98 truck. Same body, different style dash. Other than a needing new wiring harness, does this sound feasable or am I opening pandoras box?
  2. edlavarreda
    edlavarreda Registered Member
    Nov 26, 2002
    56
    ONE OF MY FRIENDS PUT A 99 DASH ON 79 TRUCK. YOURS SHOULD BE EASY TO DO
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    A co-worker did this when I worked at the wrecking yard.
    I think dash supports were taken from a donor truck and welded to the inside firewall. Also some of the holes in the firewall are different (column & harness for sure). You need the column and all heater components to match. Stay with a '95 donor as this is still TBI.
    Connectors for the other harnesses probably changed with the interior restyle... Some splicing to do anyways.
