Daytime Running Lights Problem
Discussion in 'The Garage' started by big jimmy 91, Oct 8, 2004.
  1. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    The lights just stopped working a couple of days ago.
    When I set and release the "E" brake , the indicator light in the dash will just flash slightly (just enough to see it briefly)
    Does anyone know what is wrong with them and how to fix them?
  2. big jimmy 91
    Feb 21, 2004
    639
  3. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    Dude, a little info on the vehicle could help. A lot of vehicles have DRL's- from a Cavalier to a Freightliner. /forums/images/graemlins/thinking.gif
  4. big jimmy 91
    Feb 21, 2004
    639
    All the info is in my profile , I did'nt think that I had to put it in every post /forums/images/graemlins/dunno.gif
    It's a 91 jimmy full size 350 700R with no electrical mods.
    Does anyone know what controls the auto running lights?
    They just stopped working the other day /forums/images/graemlins/confused.gif
  5. hawkeye649
    hawkeye649 1/2 ton status
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I'm looking in my 1991 GM service manual, and the DRL is kinda sparse/sucks.
    Do your dome lights work correctly?
    Do your high beams work correctly?
    It says to check both of those before starting any diagnostics. We'll go from there....
  6. big jimmy 91
    Feb 21, 2004
    639
    Thanks , I will check the high beams , the dome lights work still(the one between the front seats never did work , but the one in the back seat has allways worked)
    I do believe the high low beams work though /forums/images/graemlins/thinking.gif
    So any info would be greatly appreciated /forums/images/graemlins/waytogo.gif
  7. big jimmy 91
    Feb 21, 2004
    639
    Does anyone know if there is a module to control the DRL like the one in my furd aerostar?
  8. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    I'm pretty sure there is, I haven't read the whole DRL bit in my (factory) service manual. It's strange that the front dome never worked... Under the carpet by the kickpanel on the driver's side there is an orange and white wire. The orange one usually corrodes out, causing the domes not to work.
    I'm not at my house right now, so I can't help you until sometime tomorrow.
  9. big jimmy 91
    Feb 21, 2004
    639
    I'll be on tomorow so if you have a manual that would really help /forums/images/graemlins/bow.gif
    It's allway's a pain to figure things out without the books to help /forums/images/graemlins/waytogo.gif
  10. 90v1500
    90v1500 Registered Member
    Oct 1, 2004
    56
    Huntsville, AL
    If i remeber right, the daytime running lights have a switch on the e-brake that turn them off when the e-brake is engaged. I don't know if its a NC or NO switch but I'd start there. Just my .02
  11. big jimmy 91
    Feb 21, 2004
    639
    It seems that I have more problems now , ds. headlight is normal but ps. hl. looks like it is only half power when the headlights are turned on. /forums/images/graemlins/confused.gif
    Could this be a ground problem?
    Or is it related to the DRL not working problem?
    Anyone dealt with this problem before?
    I need to get it fixed soon as the days are getting shorter
    /forums/images/graemlins/ears.gif
  12. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    For me this was my headlight switch. The filament inside that changed the brightness of my dash lights had broken and was cooking everything. That maybe? Fuses? /forums/images/graemlins/confused.gif
  13. big jimmy 91
    Feb 21, 2004
    639
    Does anyone have a wiring diagram that might show me whats what? /forums/images/graemlins/ears.gif
  14. hawkeye649
    Mar 26, 2004
    848
    New Hamp-shi-ah
    Re: Daytime Running Lights Problem *pics*
    I hope this will suffice. /forums/images/graemlins/frown.gif
    It was the best I could do... /forums/images/graemlins/confused.gif
  15. big jimmy 91
    Feb 21, 2004
    639
    Thanks for the info /forums/images/graemlins/waytogo.gif
    It turns out that it was all caused by a bad connection at the passenger side head light (green terminal illness)
    It caused the ps headlight to run only half power all the time and this caused the DRL system to stop working
    I just fixed up the connections and bingo it's all good again
    Thanks again for everyones help especially hawkeye 649 for the diagrams and trouble shooting guide /forums/images/graemlins/thumb.gif
