DBLAZER do you........
Discussion in 'Audio' started by fr8train, Nov 1, 2000.
  1. fr8train
    fr8train 1/2 ton status
    Aug 2, 2000
    1,712
    Maryland
    Build custom over head consoles at your shop? Is it feasable to make a console, that I can put a CB and my head unit in? I was planning to do this and use the aircraft style lights from J.C. Whitney. I was going to pull the power from the dome light, thru a fused dist. block in the console. I am planning this out safely.
  2. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
    Its not sometih I do daily, but its totally feesable. As far pulling power from the dome light, thast ok, that is where the radio gets its constant power, they are the same circuite, as long as you fus the cb close to the unit. The CB probably only has a 5 or 10 amp fuse and the dome light is more like 20. Should work fine.
    http://dblazer.coloradok5.com
