Dblazer or anybody?
Discussion in 'Audio' started by Rebel-Rider, Jan 28, 2002.
  1. Rebel-Rider
    Rebel-Rider 1/2 ton status
    Sep 30, 2001
    134
    North Dakota
    i was wondering how a rockford fosgate punch HX2 15" in a ported box would sound, hooked up to a 600watt profile clarus amp, also do you like the punch HX2 why or why not,
    is the profile a decent amp or should i just save some more money and get a rockford amp to
  2. Rebel-Rider
    Sep 30, 2001
    134
    North Dakota
  3. WakeBoard&4X4er
    WakeBoard&4X4er 1/2 ton status
    Jun 29, 2000
    2,325
    Lee's Summit, Mo
    For a rockford fosgate punch HX2 15, i would think that you would be better off with a cleaner amp. or just get some less exp. subs. at one time i had a low end lanzar 15 and a lagezy 600 and it did not sound half bad. but is was in a honda Accord.
    91 K5 and 73 Cobalt http://brettmcox.rockcrawler.com
  4. im_2gr82h8
    im_2gr82h8 Registered Member
    Apr 4, 2001
    91
    federal way, washington
    cleanness of the amp is of no worries when running subs. you will never hear the difference, same goes for the rca's you use. But back to your question, the hx2's are great subs, im thinking of getting 4 for my rig, the only problem is they are VERY power hungry. i would definitely save up for a rockford amp. The amp you should use is a BD110001 (1000.1 power series) tehy are a class d amp and put out around 1200 watts at 2 ohms. Keep in mind that while not needed you should also run a 1 farad cap to the amp. oh yeah, youll need 4 guage wire as well. but as far as saving up, since all the "new" 2002 gear is comming out you can get those amps dirt cheep (less than $460) if you were in wa I'd tell you to come see me and I would take care of you, but yoiu should be able to find them at 400 if you look hard enough.
    As for ported box, they sound much louder in a ported box as compaired to sealed, but you do loose some sound wquality. all depends on how you listen to your music, if you like to play loud, go with a ported box MADE TO THE SPECS of the subs. that is what will make or break how they sound. if you run with the top off most of the time and you dont listen to rock, then you might want to consider a bandpass as well.
    hope that helps, if you have any more ?'s feel free to ask
  5. wahbob
    wahbob Registered Member
    Dec 27, 2001
    76
    Austin,Texas
    HX2= excellent, but like it was said before they are also power hungry. As for the Profile amp, i persnally dont care for them but I have heard some decent things about the Clarus line. With 600 watts and a ported box you could probably push the 15 - just not reach its full potential. I would save up for a different amp if I were you.
