DC to AC. Any other options besides an inverter for $100?
Discussion in 'The Garage' started by stu454, Sep 25, 2003.
  1. stu454
    stu454 1/2 ton status
    Sep 17, 2003
    129
    Corte Madera, CA
    I'm interested in setting up AC outlets in the Tahoe (and untimately the '73). What are my options? I've found and inverter for sale that offers 400 watts and 18 amps for about $100.
    Your thoughts are always appreciated.
    Stu
  2. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    ......how about a larger inverter for $200??? /forums/images/graemlins/grin.gif
    What is your actual question? Are you trying to come up with a solution that's even cheaper than $100, or just trying to confirm that the inverter you're looking at is worth getting???
    /forums/images/graemlins/thinking.gif
  3. MarcS
    MarcS 1/2 ton status
    Oct 4, 2002
    515
    NJ
    Try some boating catalogs. West Marine, Boat U/S & Defender Marine are probally the biggest. They have web sites and a pretty large selection of inverters. It all comes down to $$$
  4. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    Cabela's sells an 800 watt inverter for $100. That's the way to go. /forums/images/graemlins/thumb.gif
  5. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    Costco has a 400 watt inverter for only $25. Also, a 400 watt inverter doesn't put out 18 amps, so I'm not sure where you saw that. An inverter that puts out 18 amps is closer to 2000 watts.
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What are you going to use the outlets for? That's what will detirmine how much money you should think about spending.
  7. stu454
    Sep 17, 2003
    129
    Corte Madera, CA
    Ahhhhh. Good question. Small electronics like radios and whatnot.
  8. scrappy88
    Mar 14, 2003
    314
    Loveland, CO
    You should be able to get by with as little as 200 watts. I have a 140 watt that I've used for radios, my Dremel, and other small things and never had any problems. /forums/images/graemlins/thumb.gif
  9. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    If you have high drain devices, you might want to stay away or use the alternate head (instead of the cigarette lighter, use a direct power source). Other than that, there are sine wave models out there if you have sensitive devices. most things arent that sensitive, so take your pick.
  10. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    For 100 bucks you might want to look at one of these from northerntool.com
    I have a 1000 watt inverter in my K5. It will run most anything up to 1/2 hp. Kinda handy to have lots of power in the hills. Espically for the Blender /forums/images/graemlins/wink.gif
  11. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    I run the smallest inverter available and it is enough to run my laptop. I even ran a 9" TV/VCR combo off it. Nothing like taking my south park collection of video tapes along camping /forums/images/graemlins/thumb.gif
  12. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    I use my 300 watt inverter to run my 25" tv and Dish Network reciever when I go camping. /forums/images/graemlins/cool.gif
  13. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    I have a 400 watt normal operating/800 watt surge that I bought at Sam's Club and it has never let me down. It doesn't sound like much but short of runnin a coffee pot or somethin like that that draws bunches of amps there's not that much to worry about. Just my two cents worth. Good luck to you.
    Allan
  14. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Look at constant Watts.
    Watts = Volts * Amps
    An inverter rated at a constant 200 Watts will support devices that draw no more than 2 amps (200 / 110).
    It will draw around 20 amps (or more) to put out that 2 amps. (20 x 12 = 240). The overage (loss) is due to resistive losses dissipated as heat.
    So, figure out what you need to run and what it will draw (amps). Then figure out the Watts required for that amperage to choose the inverter. Make sure to look at constant draw on each, not peak, although devices that have high startup demand may require you to look at peaks.
    Once you have the inverter, calculate the input amperage and add 20% or so for loss. The inverter may tell you what the loss is. Anyway, take that and make sure you have big enough wire on the input to handle the amps (constant and peak). Also make sure it can get enough air flow to take care of the power lost as heat...
    That's a simplification and roughly accurate. Close enough anyway, unless I'm mistaken...
  15. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    /forums/images/graemlins/thumb.gif "I find your abundance of knowledge disturbing" /forums/images/graemlins/thumb.gif
    ...ps, looks like I'm bringing you a tranny at BB03 after all....
  16. heavy4x4
    Aug 28, 2002
    3,270
    I've done a lot of camping...sounds like camping in your area is a little different. /forums/images/graemlins/smirk.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  17. stu454
    Sep 17, 2003
    129
    Corte Madera, CA
    Thanks for all the help, y'all.
