DD dodge is getting H2 rims
Discussion in 'Tow & Trailer' started by DEMON44, Jul 7, 2006.
  1. DEMON44
    DEMON44 Low-Tech Redneck
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    1 done. Cut stock center cap to fit. Works good. Now just need 17" rubber to complete the deal. :D
  2. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    looks good, but where is your jackstand? :doah:
  3. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    there in the garage................which I noticed after I was finished. Got a little tunnel vision putting it on :doah:
  4. jolane
    jolane 1/2 ton status
    May 27, 2004
    132
    I don't want to start a debate...but why would you need a jack stand for changing a wheel? It is probably the safest thing to do, if you can get one in place, but isn't that a little overkill. Yes, keep your legs out from under the vehicle...which shouldn't be hard to do if JUST changing a tire. No doubt you should have a JS if under the vehicle...
    Just curious is all...
    Joshua
  5. bigjbear
    Feb 18, 2000
    13,971
    451
    Marietta GA
    Those are going to look great.
  6. vtblazer
    vtblazer 1/2 ton status GMOTM Winner
    Sep 30, 2003
    2,471
    Central VT
    Did the same thing on my chevy. :D
    How much 'customizing' did you need to do to your center caps? Looks good.
  7. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    How hard is it to get the center caps to stay on?
  8. vtblazer
    Sep 30, 2003
    2,471
    Central VT
    It's not.
    Just use the stock lug nuts with the threads on them.
  9. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    The Dodge centers are different than those GM ones. Mine are snap-tite not thread on. I had to cut the plastic skirt about 3/4" then the metal retainer. about 1/16"-1/8" so it would fully seat inside the hummer rim.
  10. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    dyno'd today.............242RWHP on a mustang dyno...................517ftlbs
    Not bad for a stock engine...........factory rated at 235hp :doah:
    just a baseline # now though.................Its on its way up.
  11. DEMON44
    Jan 8, 2003
    7,232
    15
    Okotoks, Alberta
    finally pics. 35" BFG M/Ts stock centers need a little more massaging though....
