DD with manual VB....WITH POLL!
Discussion in 'The Garage' started by NEK5, Aug 8, 2006.
DD a manual VB?
  1. do it.......nekkid
    20 vote(s)
    90.9%
  2. just get the regular gate shifter and ride the gears when you want to......nekkid
    2 vote(s)
    9.1%
  1. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    how many of you do it? i`m contemplating the idea, but would really like some feed back from you guys that have done it, i`m running a 700r4, and want to get the TCi reverse manual valve body, and an Art Carr reverse pattern shifter, but i`m wondering if i should not do it, and just get the regular Art Carr gate shifter, so i can go throught the gears when i want...my rig will only see minor offroading, so nothing like rock crawling....but is more a DD than anything
  2. 2Dogs
    May 4, 2001
    3,470
    35
    Ca
    DO IT!
    And tell us how it works - I want that setup as well :D
  3. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    do you DD your rig? just wondering if it will be right for a DD
  4. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Do it, just don't let friends drive it with out know how to drive it or they will burn it up.
  5. jekbrown
    May 19, 2001
    45,030
    364
    Vancouver, WA, USA
    yeah, so long as you remember to shift when you should be shifting, it oughta work fine on a DD. Pretty much a manual trans without the 3rd-leg pedal.
    j
  6. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Just make sure the rest of your drivetrain is up to it. With the VB it will shift SUPER hard since every gear is getting full pressure. So if you are running stock size 1310 u-joints you might think about upgrading. Other then that the few times that I have cruzed around the block in my truggy is is VERY fun to drive. especially with such fast shifting it really gets up and goes:D
  7. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I had a MVB in my car that I sold, wasn't a DD, but I drove it alot. It got tiresome after awhile. You have to shift it everytime, and in stop and go that sucks. It's nice cause you can start in 2nd if needed, or hold it in gear till you shifted it. I guess what I'm trying to say, it gets old pretty quick.
  8. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    Just get the gate shifter. When I still had my blazer with the 6.0/4l80e, I had a similar shifter from B&M called their truck megashifter, and I drove it for a few weeks shifting everywhere. It got old though and was kind of nice to have the option to just leave it in OD sometimes. But yeah its fun as hell to wind out all the gears and have control of your own shift points.
    Remington
  9. ivie29
    ivie29 1/2 ton status
    Apr 26, 2006
    212
    gypsum, colorado
    I put a manual vb in my th 400 and if you put it in drive it works about the same as a normal auto. The only difference is you can downshift when ever you want and it will hold whatever gear you select until you upshift.It also shifts much harder.
    The reason I installed mine was for mud races, it helps for crawling but not as much as you would think.
  10. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    would letting off the gas when you shift make a difference?? i`m still debating this, and i`m leaning more towards just getting the shifter, but maybe i just need a little persuasion:D
  11. NEK5
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    thats what i`m thinking
  12. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    the shifts with the manual vb are pretty bad, but you can let off the gas. I dont know how good it is on the torque converter but I have been doing that with mine and I drive it quite alot. No probalems yet. In between shifts Ill just let off and then get back into it, makes the shifts tolerable on the street (nice and smooth acceleration), saves your drive train a little, and if you have a decent exhaust system it sounds really cool in between shifts.....ssssshhhhhhhh dont tell anyone its not a "real" manual even though sometimes it sounds that way.;)
    I quite enjoy the manual vb, dont think I would want it in a "daily" driver, even though I do drive mine pretty much daily. I do alot of cruising around the beach. and running errands. The best part is when a ricer pulls up next to me, if I decide to romp on it hard it gets up and goes. 383/400 with 5.13's and 38's. I really like being able to shift how I want it to, I wouldnt change a thing about the vb setup, except I need a little bit larger tire to get the rrr's down a little bit.
  13. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    I ran a manual setup on my TH400 and it was fine but I did not use it on a daily basis. The bigest problem I have seen in the past was customers would have a manual vb installed and forget to shift back to first at a redlight, take off hard and burn it up after doing so a few times.
    For a daily driver I would just get the gate shifter and shift it when you want to.
  14. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    People sometimes get very paranoid about their TV cable, and start thinking about a manual VB in order to get rid of the cable entirely. Even if it's adjusted right, they think it might have gotten out of adjustment somehow, and so forth.
    They might consider a trans line pressure gauge to help minimize their concerns, because that will show you if your pressure is getting boosted when you get heavy on the gas pedal (it does help to know the normal closed and full-open throttle values in each gear for your trans build). Here we are at idle in park (the rightmost gauge):
  15. fireplug
    fireplug 1/2 ton status
    May 3, 2005
    1,692
    Toronto, Canada
    You should also consider winter driving, ice and snow with hard shifts? Throw a Detroit into the mix and you could have a 'real fun time'.
  16. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    you do realize that drifting is cool these days, right?:haha:
  17. BrianDamage
    BrianDamage 1/2 ton status
    May 14, 2001
    753
    Alabama
    nevermind
  18. K5er4Life
    Oct 16, 2002
    1,456
    Bellflower, Ca
    i havent had mine in the snow but even in the rain alone it makes for real fun driving with 5.13's and a detroit. Hell even when its dry out if I come around a corner and get on it at about half throttle the ass end of my truck pitches way sideways and starts roostin 38's. :eek1: :saweet:
