dead battery
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by 69K5, Dec 18, 2001.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    Well I pulled out my friend with my winch the other day and ever since my battery keeps going dead. I disconnected the winch because this is the first time I had conected it in the two months I've had the blazer. It still keeps going dead. I can jump it off very easily with like 10 - 15 seconds of charging off my wifes hyandai. I disconnected the positive battery cable with it running and it kept running. so I diont think its the alternator. The battery sticker says it is only 18 months old though. I'm gonna take both to get them checked tommorow at autozone. Just thought I would run it through here first. The winch is a Viking winch. I think its a 10,000lb. they havent made them since 77 . Its a worm gear driven with I think it says 90 : 1 pullin ratio. Any ideas? and whats the cheapest way to do a dual battery set up? thanks in advance!
    69K5 (nathan)
  2. Steve_Chin
    Steve_Chin 1/2 ton status
    Mar 6, 2001
    1,126
    Foster City, CA, USA
    Was the engine running when the winching was being done? Sounds like you have a couple of dead or dying cells that will not hold a charge in your battery... Get it replaced under warranty. A dual battery setup might help somewhat in this kind of situation if it was the winching that killed the battery...
  3. chevyracing
    chevyracing 1/2 ton status
    Sep 8, 2001
    2,589
    Colorado
    I think Steve hit it on the head. Just out of curiosity,,,,,,, Did anyone see your wife jump starting your K-5 with a hyundai? If so I hope you hung out of the window and said.,"okay Miss, try it now....LMFAO!!!!!
    John
    Like to go sloppin' 'round in da mud in a rapid fashion....=)
    <a target="_blank" href=http://coloradok5.com/gallery/albun31?&page=1>BLAZER PICS</a>
  4. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    I swapped out the battery with a brand new one and she cranked right up. luckily no one saw my wife jumping off the blazer. I think one of my solenoids might be stuck open. how do I test it?thanks
    nathan
