Dead Battery
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by inaminute5150, Sep 28, 2002.
  1. inaminute5150
    inaminute5150 Registered Member
    Apr 16, 2002
    15
    west coast California Vacaville
    <font color="blue"> </font color> I have an 89 full size Blazer, I happen to walk near the rear and heard this buzzn noise ,being that there really isn't anything electrical in the area so i assumed it was the fuel pump!I hopped in and started it up,starts right away didn't think much of it at the time.To make a long story short, came out the next a.m found the battery deader than a church house mouse!!!Amagine my shock.Well took the battery to local parts,they test and explained that i need a new battery as this is beyond F.U.B.A.R!!!!!!!First ? is as to why would the pump keep running ,even with the ignition in the off position? Second if it wasn't the fuel pump,what could've been making the buzzin noise from the rear,even with everything off what could it been? Also is this a common Problem? /forums/images/icons/confused.gif
  2. tipoil
    tipoil 1/2 ton status
    Jul 30, 2002
    222
    canada guebec
    rear window motor??? maybe!!!
    hope it helped a bit!!
  3. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    Even if something would have been running, that should not have killed the battery, drained it,yes...killed it, no. /forums/images/icons/confused.gif
