Dead Optima? Dead blazer after few weeks of not starting my baby...
Discussion in 'The Garage' started by juanblzer, Dec 10, 2004.
  1. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    I went to start my blazer for the "wrestler's car show" and it won't even turn over. I jumped it and it started up but then when I turned it off it wouldnt restart and now it won't take a charge.
    I have an optima battery (redtop) in it. Do I need to pull it. I dont have a trickle charger just another rig to jump it.
    Any ideas?
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Your optima is junk. When you get a new battery, I suggest you not get an optima. A discharged optima will sulfate VERY quickly (which you found out) and without any free acid, they will not take a recharge.
    Time for a new battery. This is how nearly every optima I've ever sold has failed, and come back.
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Sounds like the battery is toast. Probably going to need a new one.
    I have heard that if the plates in an Optima are stuck together that sometimes if you drop it from a few feet in the air onto concrete you can break the plates apart and get the battery to take a charge again. It is worth a shot. If that don't work then I would say your battery is a goner.
    Harley
  4. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    , i have killed the batt. (optima) several times in the MINI and it is still going like a charm, i just went out and started it after not running it for a month and it started right up.:waytogo:
  5. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I killed my optima like that as well. Was dead as a door nob. Couldnt recharge it.
    i have yet to try the "drop" but I've got 2 dead optimas that im willing to give a toss to. Any particular "method" to this drop?
  6. 85burbanator
    85burbanator 1/2 ton status
    Feb 10, 2003
    577
    lake orion, mi
    i thought they were supposed to last a long time and recharge better then most batteries?i got a yellow top thats been sitting in the garage afor a few years. it was bad when we took it out and i was going to try to recharge it to put in the blazer. maybe ill have to shell out some more money for another battery.
  7. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I believe optimas have at least a 2yr warranty on them. I have a red top. I would try taking it to where you purchased it and try to get a replacemment. Couldn't hurt to call them and ask?? :laugh:
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Nope. The design of them is for increased resistance to vibration and faster recharging by less internal resistance.
    Optimas are the absolute worst design to discharge, leave discharged for too long, and try to get them to bounce back. It's just prohibitive of the design to be that way.
  9. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I just had a Red top that was Dead as a door nail and it took almost 2 days before it took a charge, But it did charge.
  10. bigred81
    bigred81 1/2 ton status
    Dec 5, 2003
    323
    Falls City,TX
    You are suppose to slow charge optima batteries or you will cook them and it will never hold a charge. From what you said it sounds like you might have something pulling your barrery down. Might want to have the alternator checked to see if it has bad diodes.
    bigred81
  11. azblazer
    azblazer 1/2 ton status Premium Member
    Jul 20, 2003
    695
    15
    Grand Junction, Co.
    I just bought a new one from autozone and it was junk...checked my k5 for a draw and found squat. The story i got was that they have been bought out by Interstate.....and the quality has gone to sh--. They replaced mine and so far this one has had no issues.
    DW
  12. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    I concur. I left the keys in the ignition of my burb one time when it was not operational for like a week and it drained my redtop dead as a doornail. I tried to recharge it quickly with my uber-badass do anything charger and it wouldnt take a charge. The battery got really hot and some clear stuff bubbled out of the two black hole things in the top. I tried charging it slowly overnight after that and it worked just fine. No problems to date with it.
  13. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    My alarm killed my Optima a few times. I couldn't jump it becasue it was so low. I took it out and hooked it up to a charger overnight and it has worked great. I finnaly disconnected my alarm and even after a few months of not starting the truck it starts with noe problem.:D
  14. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    False. Interstate does not, and has not ever, made car batteries.
    Batteries in this country are made by one of three manufacturers. Johnson controls, East Penn, or Exide.
    Interstate's batteries are made by Johnson Controls. So are Autozone's, and Optimas.
    The design (with no free acid) has always been prohibitive from discharging and recharging, even more so than any plate/acid type non-deep cycle car battery.
  15. bigcountryk5
    bigcountryk5 1/2 ton status
    Mar 13, 2004
    931
    G-vegas(Greenville) South Carolina
    A deep cycle battery is designed to be discharged 80%.
    Then recharged to 100%. These style batteries are designed to deliver a
    consistent discharge rate for a given amount of time. Unlike starting batteries that are designed to give a large amount of current quickly(starting your truck)but usually are only good for a limited amount of cranks. A good example is when you leave your lights on.
    if your gonna run a deep cycle batt the best use would be as an aux. power source i.e. lights radio winch etc. you need a good starting batt to crank your truck
    and the dropping idea is not a great one i've seen it work and i've seen it crack batt's too.
  16. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    how old is your and where did you buy it? have you tried exchanging it yet? If your just going to junk it could I get it from you for a mock-up battery
