Dear lord please help
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Mudweiser79, Dec 10, 2002.
  1. Mudweiser79
    Mudweiser79 Registered Member
    Dec 10, 2000
    34
    well, right in the middle of exams, and my truck (90 k5 w/TBI) is getting no power....except to the dome lights!! It was running fine as of last night, I went out this morning to get something and there was no power...Battery is at 13.2V, all fuses are good, no crank, no radio, no power widows, nothing works, someone help!
  2. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    check the battery cable. could be a bad connection or a bad cable
  3. Mudweiser79
    Dec 10, 2000
    34
    first thing I checked, perfect continuity
  4. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    replace the battery....
    if everythign works.....
    Just swap batteries with a buddy for a day, it wont jump either will it...
  5. Mudweiser79
    Dec 10, 2000
    34
    well, the battery has sufficient voltage, and what I don't understand is that the dome lights, headlights, and instrument lights are working fine.....I can give it a try though
  6. Panther
    Panther 1/2 ton status
    Aug 31, 2000
    845
    South Jersey
    A near dead battery should have the right voltage. It's the amps that turn the starter. You should at least get a clicking though if the battery's dead. Try another one first.
    Second, the dome lights, etc are not ignition run power. They can run and the truck might not start (ask me how I know /forums/images/graemlins/laugh.gif ). You need to check the voltage underneath the truck at the starter to check continuity (be careful). You should have a constant voltage on the big lead and only voltage on the smaller lead when you turn the key.
  7. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    did you beat on the starter yet?
  8. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Do you, or did you have an alarm that may have malfunctioned & is acting like an ignition kill?
  9. Mudweiser79
    Dec 10, 2000
    34
    There's no servo click as you usually get with a dead battery, it's got a brand new starter so I'm pretty sure the brushes aren't worn enough to require shaking, and I do have an alarm, but I disconnected it and the problem was still there.
  10. 86 4door
    86 4door Registered Member
    Nov 28, 2002
    15
    pottstown PA
    look on the back of your alternator at the hot wire from the battery to the alternator.make sure the wire is still conected and not broke off
  11. You might want to check your starter to see if it's still there ... someone may have stolen it! /forums/images/graemlins/eek.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  12. Mudweiser79
    Dec 10, 2000
    34
    haha haha very funy jackass
  13. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well I am not trying to be funny but did you check the fuses, and did you try to start it directly from the starter?
    You need to narrow it down some more.
    I have had the ignition go bad on me and had the same thing.
    If you can turn the starter by bridging the posts on it then your problem is in the ignition.
  14. caryhenry
    caryhenry Registered Member
    Sep 28, 2002
    78
    Tallahassee, Fl
    sounds like an ignition switch problem to me, because the stuff that isn't working requires the ignition switch to be in the "on" position.h
  15. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    Look at his other post, Rockin was right, someone stole his starter. /forums/images/graemlins/frown.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/confused.gif
  16. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    fuse link? i qwned a dodge /forums/images/graemlins/shocked.gif and i jhad a fuse link die on my it got me home but wouldnt start and i also had to rig the ignition on my 80 chev it starts with a toggle and somthing else /forums/images/graemlins/wink.gif /forums/images/graemlins/k5.gif
  17. imiceman44
    Aug 5, 2002
    15,160
    Sacramento, CA
    You guessed it, I am suspecting you flew all the the way over there and stole it.
  18. gpd4
    gpd4 Registered Member
    Jun 25, 2001
    55
    St. Louis, MO
    Check the fusible link on the firewall right next to the master cylinder. Mine popped a few weeks ago - same thing happened. No dash lights, no nothing except headlights and dome light. It is a "Y" link, so I bought two and seperated them. One of them still gets a little warm, but I haven't had time to track the problem down. For $1.50 and a quick connect wire thing, I can be rolling again in 5 minutes...
  19. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    He figured it out. His starter was stolen! /forums/images/graemlins/tongue.gif
