Death wobble, 4WPW, Steering Stablizer ?'s
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by zakk, Nov 22, 2001.
  1. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    Death wobble, 4WPW, Steering Stablizer ?\'s
    wanted the blazer ready for the weekend hollister run, death wobble after 1 ton conversion is getting bad. went to 4WPW (needed parts fast) and got a Rancho 3/4 ton front stabelizer. guy SWORE it would work, well it doesn't. Any suggestions 4 a good stablizer?
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Re: Death wobble, 4WPW, Steering Stablizer ?\'s
    My suggestion is fix the real problem, since apparently the band-aid fix didn't work.
    Time to replace drag link ends, tie rod ends, and make sure your wheel bearings are squared away. If it's still crappy, replace the steering box.
    It's my understanding that a good steering stabilizer can really help....but I've never replaced mine, it's nearly 20 years old, and I don't have any steering problems...no wandering or anything. You have to make sure your steering parts are good and fix the real problem--then you can enjoy using the steering stabilizer for what it's meant to do--not to hide bad parts in the front end.
    Tim
  3. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Go for the TrailMaster PN 57201 coilover stabilizer. You can (KINDA[​IMG])see a pic ROCKYMOUNTAINSUSP.COM. Cost $86 with shipping to my door!
    Good luck!
    <font color=red>GOT MUD???</font color=red>
    My license plate reads:<font color=blue> 8 YR SUV</font color=blue>
    <a target="_blank" href=http://24.10.209.54/bigolk5.htm>http://24.10.209.54/bigolk5.htm</a>
    454/TH400/NP205 - 14BFF/D60/w/ 4.10s
  4. KRAZIE87K5
    Feb 23, 2001
    3,369
    Chicago, IL
    You know what?!!! 84_Chevy_K10 is totally right too... I forgot that I already have brand new front susp. parts, so all the tie rods are true (straight), the ends are all tight, and the steering box has already been tightened up after having the sector shaft replaced, and rebuilt.
    So I agree, get a fattened up thanksgiving bud to hop into the truck and turn the wheel left to right while you look for excess movement on the underside.
    Have fun, and happy turkey day!
  5. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    well it is not that the rancho did not work. it did not fit. the steering isn't sloppy. tie-rod ends are and idea as is the drag link. anyway to tell if i really do need to replace them or just go for it??
    -Zakk
  6. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    for some reason the d60 is more prone to DW
    dual stabilizers is the band aid, the solution is usually tires
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Take it to a front end alignment shop and have them check the caster angle. If it isn't right, then the death wobble will kick in. It's just like the wheel on a shopping cart that goes crazy after its mount is bent. [​IMG]
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    ok...i got used hummer tires &amp; they are bearly balanced. still saving up for 39.5 but need the x-over steering before that. I have no idea what "caster angle" is and do not pretend too. got a good explaination? i am all ears...[​IMG]
    -Zakk
  9. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    The shopping cart is the best way to illustrate caster angle. Even though we're guys we all have at least seen a shopping cart...OK some of us have only heard of them from our wives and GF's.[​IMG] Check one out and watch the front wheels as you push it. The front wheels always 'track' in the direction the cart is being pushed. Although a front diff is very different from a shopping cart the principle is the same. Caster angle is built into the axle at the knuckle and allows the truck to track down the road with no steering effort. As you lift a truck the diff is rotated slightly which effectively reduces your caster angle and can cause some squirrelyness (is that a word?[​IMG]) and also DW if the steering components are worn.
    Caster also helps return the steering wheel to center when coming out of a turn.
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  10. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    thanks Rene...sounds like i need to take it to a shop to be checked
    BTW Rita (Mrs. Zakk) thinks your turtle is "cute" [​IMG]
    -Zakk
  11. tRustyK5
    Jul 23, 2000
    36,169
    1,372
    E-town baby!
    Now ya know why that turtle looks so 'stupid-happy'...the chicks love him.[​IMG]
    Rene
  12. michaelm
    Feb 2, 2001
    872
    even with caster set, and entirely new axle and steering components, my d60 suffered DW
  13. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    "suffered" past-tense would denote you cured it. how did you fix it in your case??
    -Zakk
  14. michaelm
    Feb 2, 2001
    872
    well i hid the problem with dual stabilizers
    hoping losing the intercos will be a huge step
    will have to see if its gone when i finish current projects
    will not claim victory yet
  15. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Did you check the king pin bushings and also if you used a steering block make sure the bushing is down on the king pin the whole way and the round metal piece is in the block to hold it down.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
