Death Wobble! Need HELP!!!
Discussion in 'The Garage' started by mudbog42, Apr 21, 2007.
  1. mudbog42
    mudbog42 1/2 ton status
    Jul 16, 2006
    452
    Florida for now
    Ok I am watching my buddy's 89 K-5 fo him while he is deployed.:deal:
    The problem is that from a cold start when the truck gets up to about 20MPH it will wobble all over the place really bad,:yikes: feels like a tire is gonna fall off or something, its bad:what:
    And then after you stop it won't do it any more until you let it sit till its cold again and then it will do it again,:dunno: but it will only do it that one time and then its fine:thinking:
    Does anybody know what this could be?:1zhelp:
    Also its got a 14BSF in the rear and a 10 bolt up front
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Something loose in the steering. Check the ball joints, TRE's, DLE's and Wheel bearings.
  3. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Death wobble is a tricky one. It could be one thing or a combination of many things. In addition to what readymix already suggested you check out, take a close look at your steering box, alignment, and tire balance. Basically, anything that's out of whack in the front end could be causing it.
  4. goldwing2000
    goldwing2000 Guest
    Does it have bias-ply tires?
  5. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    my first thought when I read the original post, and how long has it been sitting before you drove it?
  6. mudbog42
    Jul 16, 2006
    452
    Florida for now
    Not sure it has Pro Comp X-terrains
  7. mudbog42
    Jul 16, 2006
    452
    Florida for now
    Its only sat a couple of days
  8. dleroy43
    dleroy43 1/2 ton status GMOTM Winner
    Jul 22, 2002
    1,517
    Martinsburg WV
    So my tie rod bent to the top of the pumpkin, wornout chunked SXs, and rock rashed bent rims may be the couse of my DW? :doah:
    I noticed air pressure makes a differance too
