Death wobble on acceleration
Discussion in 'Pacific Region' started by The85k5, May 16, 2002.
  1. The85k5
    The85k5 1/2 ton status
    Feb 22, 2001
    259
    Sunnyvale,Ca
    I already posted this in the 73-91 forum but i need help ! /forums/images/icons/smile.gif
    Okay today i was driving along....and some dumb jetta trys to cut me off, so i floor it and get up to about 65....this is on a straight street and afte that from about 25 mph up....(i've only gone up to 50) it wobbles like crazy but only when i'm on the gas! it will start wobbleing even if i barely have my foot on the peddle....any idea's???? it sux having a daily driver that u always gotta work on!
  2. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    I had somethin almost exactly like that happen to me just the other day. It turned out to be an almost busted u-joint on the t-case end of the rear shaft. When I got home and started checking to see if I could figure out what the vibe was, I grabbed the drive line, and it had about a 1/2' of play!! It trashed the yoke too. Not sayin this is what's wrong with your rig, but one thing to keep in mind. Also maybe ball joints or wheel bearings. Hmm, What else.....tie rod ends? Steering box loose or frame cracked? Trany/t-case mount fuxed? Motor mounts fuxed? Check and tighten u-bolts? Spring hanger and shackel bolts?
  3. The85k5
    Feb 22, 2001
    259
    Sunnyvale,Ca
    yea i didnt have anyplay....i replaced the u-joints and greased em ....put some more tranny fluid in and took it for a drive.....this time i drove about 2 blocks straight and got up to like 35....it was fine no shaking....took a turn and got on the gas again...shaking was back! so i dunno...i checked the yoke on the axle too...it was tight....now i'm stuck....man i hate driving my moms car!
  4. NoSmog73
    NoSmog73 1/2 ton status
    Sep 28, 2001
    2,348
    lodi,ca
    I would say check the wheel bearings or the u-bolts.....mike
  5. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    That sounds like ti would be a steering thing...Or atleast in the front end. Check everything steering related. From the steering shaft to the tires. Even check your lug nuts. /forums/images/icons/smile.gif Good luck. /forums/images/icons/smile.gif
  6. The85k5
    Feb 22, 2001
    259
    Sunnyvale,Ca
    well the weird part about the whole thing is well....the u-joint has been bad for like a week or longer....its been making a noise which sounds almost exactly like exhuast hitting somewhere so i figured thats what it was also because it still drove the same, well the today when i got on the gas up to like 65 it started shaking, so thats when the u-joint thing came to mind.....replaced it and no more noise but it shakes like a mo-fo!
    so i'm still stuck on what it could be....
  7. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    Check your wheel weights! Unbalanced tires are killer!
    Also check your wheel bearings I had a hub assembly freeze up and die. By the time i figured out what it was my wheel was being held on by the brakes! I figured out what it was by burning my hand on the hub.
    Also, check your yokes around the new ujoint.. make sure nothing got munched.
