death wobble question
Discussion in 'The Garage' started by ranchhand, Nov 8, 2003.
  1. ranchhand
    ranchhand Newbie
    Nov 8, 2003
    i did some searching about the infamous death wobble. from the few threads that it brought up for me, it seems to be a king pin style only problem to do with the alignment problems caused by incorrect caster. is this correct? if so, are there any concerns with a ball joint style dana 60 or d44? this site is one of the best ive seen so far guys keep up the good work /forums/images/graemlins/thumb.gif
  2. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    My 44 had it with ball joints, my 60 had it with all new parts, and I have even seen 2wd solid steering f450's have it. There are lots of little reasons DW occurs, and can sometimes be a BEEOOTCH to figure out, but here are the basics..
    -wheel bearing adjustment
    -wheel balance
    -replace parts that are worn
    -alignment (i.e.toe-in/caster angle)
    Most common fix is to call up Matt at westtexasoffroad.com
    and order the Red Neck Ram set-up /forums/images/graemlins/grin.gif Thats what I did!!
    Rob
  3. ranchhand
    ranchhand Newbie
    Nov 8, 2003
    is that legal? i know some hydraulic steering setups are not. around here you cant stay off the road getting to and from the trails
  4. yeild2me
    Jan 7, 2001
    1,309
    fayetteville, nc
    Well, in most states Hydraulic "ASSIST" is fine, because there is still a mechanical means to steer the truck. With a full hydraulic system, there is no mechanical back-up.
    BTW-Please fill out your profile, this well help people answer your questions if they know your location, rig specs, etc.
    Rob
  5. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Hyd assist is no different than what the early '70s fords had stock.
