death wobble research for you dana 60 fans
Discussion in 'The Garage' started by gpnjuice, Jul 24, 2006.
  1. gpnjuice
    gpnjuice Registered Member
    Aug 8, 2004
    44
    Ok here is some research for y'all.
    I just got done with my dana 60 install and found the dreaded Death Wobble. So I started some research. For the quick version, I added two 1/8" washers to each kingpin spring and poof no death wobble no stabilzer with cross over.
    Ya I know repost well here is the tech...
    I researched 29 other users with d60 death wobble and what their fix was reported to be. I didn't count, cross over/stabilizer/power assist since those are bandaids.....
    here is what I found of the 30 users:
    9 had loose steering that they fixed (tre's/loose steering box etc
    15 had used the washers in the kingpin
    2 fixed it with toe adjustments
    1 fixed it with caster
    2 tires
    1 brakes
    1 loose suspension
    Now before you say wait there are more than thirty. I included some that fixed loose steering and kingpin. When they did this at the same time. So moral of the story. check them kingpin springs before anything else....
    So hopefully this will help some of the research for all you other dana 60 swappers...
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I dont have a d60 but thats awesome. Good work!
  3. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I am going to rubuild my 60 soon - is this just something that I should do then?
  4. spoolnaround
    spoolnaround 1/2 ton status
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I did the washer bit and it worked for a minute. My last trip out it came back:mad: . I see a rebuild soon. I am running cross over and high steer, no ram no sablizer. After my rebuild I need to get a new ram too.
  5. cbbr
    Jul 17, 2004
    14,681
    I am going to rebuild them before installing the axle. maybe that will do.
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    IMO, the washers are also a bandaid. The rest are what I would consider a fix. And yes, I fixed mine with hydroassist, anotherbandaid. :rolleyes:
    BTW, that adds up 31 :wink1:
    Nice research thanks. Too bad it came in too late for me. Or should I say lucky me I got my hydroassist before realizing the simple washers fixes this? :p:
  7. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    If it helps your research, I put 2 1/16" washers in and it had no improvement. I'm certain it's from out of balance tires because all of the steering stuff is new and tight.
    Hydro-assist made it go away it though :) It didn't fix the core problem but it solved the symptoms.
  8. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The washers are a big bandaid. The real way to fix it is with new springs and bushings and pins if nesserary. Don't get me wrong, the washer trick is a good fix since the springs tend to wear out kind of quick.
  9. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I agree that tires have a lot to do with it. Not the cause all the time but they can amplify the problem. One thing I would consider researching is when they had death wobble were they running bias or radial tires. I would almost bet most will be on bias tires.
  10. MTMike
    Feb 10, 2005
    2,992
    Billings, Montana
    Good point...... for the record I'm running 38.5x14.5x16.5 Super Swamper TSL/SX Bias on stock HMMWV Rims.
  11. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    I agree. I went from radial 35's to bias 37's and thats when I first experienced DW...although I would say that my truck was just starting it and didn't get as violent as some have described. One washer per side almost cured mine. Its livable now until I rebuild the kingpins (soon). BTW, I didn't balance the tires - seems worthless as they change balance everytime I wheel.
  12. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I have new springs and bushings on my Dana-60, and I still had to put a 1/8" thick washer on each side. I inspected the king pins, and they are in good condition. The problem with my death wobble only started after I replaced my 33" tires with a new set of bigger 35" tires on my truck. I think another thing people need to look at is worn out bearings on the bottom of the steering knuckle. The bearings on my truck are probably the original ones, and need to be replaced.
  13. spoolnaround
    Apr 8, 2002
    1,419
    Kingsburg Ca
    I am running the same tire. I replaced the springs and bushinge before trying the washers. My steering is all new so that is out of the question for me, I am basically relating my problem to the Swamper sx's. My next move is
    bb's or golf balls and everything from the wheel bearings out, including the king pin.
  14. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    How many miles are on your axle?
  15. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    almost 170,000. Mostly street miles. The PO's never took this truck off roading, and I only take it on easy fireroads and washes when I wheel it.
  16. Can Can
    15,552
    136
    How do you know that your bottom bearings need to be replaced? Is there any physical evidence, or is it just an "it's time" thing?
    The reason I ask is that I have an ORD spring/bushing kit coming my way because I started getting the DW on the crew cab I just bought from Cam. The truck only has 57K on it, and has obviously been taken care of, so I would hope that the bottom bearings would still be good.
  17. 1-ton
    Apr 17, 2004
    2,880
    159
    Las Vegas, Nevada
    I keep getting a tire vibration on my right front (not too bad, just enough to be annoying sometimes). I have had two different sets of brand new rims and tires on the truck (rotated them too), and it still keeps getting a vibration on the right front (always at one particular speed, depending on which tire and rim is mounted to it). Everything on the front end has been replaced, but the bearings and races on the steering knuckles.
    I can also see that the lower part of the steering knuckles has about 1/8" movement on the right side, and about 1/16" on the left, even when recently greased.
    It is also based on the age of the bearings as well too.
  18. gmc4cw
    gmc4cw 1/2 ton status GMOTM Winner
    Jul 19, 2006
    3,907
    west chester, Pa
    Golf balls do not work. I worked in a commercial tire shop and saw all these remedies. Equal tire balance does work and is easier to put in your tires then golf balls. you don't need to break the bead for equal.
  19. mo
    mo 1/2 ton status
    Jun 29, 2004
    542
    Folsom, CA
    I put new bearings, bushings and springs in my 60 before i put it in. the pins seemed fine. went to 37's and got DW sometimes. Put 2 x 1/16 washers in, no more DW, now on 40's still no DW, yet...
    edit: oh yeah, used dyna beads in my 37's, 40's are balanced with stick on weights inside the rim, and adding a single steering stabilizer didn't do shat for anything :) pry should have a dual, but whatever:)
  20. DavidB
    DavidB 1/2 ton status
    Oct 8, 2001
    2,617
    El Centro, CA
    Thanks, great info.
