death wobble woes
Discussion in 'The Garage' started by 89Burben, Feb 7, 2006.
  1. 89Burben
    89Burben Registered Member
    Jan 3, 2005
    98
    CT
    ive searched, and wrenched, and have drew blood, sweat and tears.....just wanted to see if anyone had any other suggestions....
    its an 89 sub 8" superlift springs high steer, one steering stablilizer,just replaced the plastic cone and spring on kingpins, brand new tre's, have the alignment toed in an 1/8". this didnt fix it so i took out the aluminum shims to change the castor somewhat back to stock and it still didnt fix it. Am i changing the castor in the correct direction or should it be shimmed more up towards the transfer case?
    this happends with 31" tires, 38's and 40's.......
    help palease
    brian
  2. Leper
    Leper 1/2 ton status
    Feb 18, 2005
    4,437
    Dallas Baby!!!!
    Are you using crossover steering?? If not, that could be much of the problem.
  3. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    you need to put fender washers under each cap
  4. 89Burben
    Jan 3, 2005
    98
    CT
    im using high steer
    even since the springs and cones are new??
  5. tRustyK5
    Jul 23, 2000
    36,169
    1,367
    E-town baby!
    Yes...there isn't enough king pin spring pre-load to keep the bushings firmly on the king pins. Home depot sells 1/2" fender washers. They're 1/16" thick and 2" in diameter with a 1/2" hole. I used two per side and have no death wobble, that's with unbalanced 39.5's.
    Try one per side first and if you still have DW try two per side. They're easy to install, cost next to nothing and cure the problem...
    Rene
  6. 89Burben
    Jan 3, 2005
    98
    CT
    alright but what doesnt make sence is that i have 31's on the truck now, and its doing it like crasy....
  7. 89Burben
    Jan 3, 2005
    98
    CT
    i put in a 1/8" washer on each side and it seems good, no wobble, but it might be too thick of a washer b/c when you are turning, it doesn't like to turn back to center so im going to try to get those 1/2" fender washers that are 1/16th of an inch thick...
    thanks!
  8. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    yeah but for a possible cheap fix id say its worth a shot from what i've been reading.
