"death wobble"
Discussion in 'The Garage' started by 86chevybanshee, Jul 6, 2004.
  1. 86chevybanshee
    86chevybanshee 1/2 ton status
    May 15, 2004
    917
    beverly MA
    \"death wobble\"
    is there a fix for "death wobble"?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Re: \"death wobble\"
    ball joints for a 10b/d44
    kingpin rebuild kit for d60
  3. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    axle has brand new ball joints, tierod ends ans draglink
  4. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Most times that doesnt help either. I have found on my D60 that toe and tire pressure change at what speed and how bad it is. I am down to no steering stabilizer and almost no noticable wobble anymore.
  5. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    oh yeah i dont have a steering stabilizer
  6. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    it has 38.5 swamper tsl's, they are pretty bald, and i am running about 30 psi in them
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    1. You have WAYYYYYYYY too much air in those Swampers.
    2. You need a steering stabilizer.
    3. Get your truck aligned.
  8. burbBoy
    Feb 4, 2002
    358
    WI
    I run my 40" TSL's at 15 or so. 30 is to much IMO. Toe will be hapy between 1/4" in or 1/4" out in most cases. Its a trial and error type fix. Change toe and in a bit and take it for a ride and see what it does.
  9. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    ok then whats a good pressure to run?, i have a stabilizer on they way. the allignment is pretty good.
  10. backcountry
    backcountry 1/2 ton status
    May 27, 2004
    916
    Need to have you front end alligned by a repetable place and have tires balanced. /forums/images/graemlins/peace.gif
  11. Ryan B.
    Jul 18, 2001
    5,693
    CA
    no real cure for deathwobble.
    The band aid fix has been putting a hydro assist ram on the tierod to absorb the wobble... the other fix has been putting some fender washers in the kingpin cap to increase the preload on the kingping bushing spring.
    I now have about 7000 miles on my 1 ton axles, and i didn't get a hint of deathwobble until about 2500 to 3000 miles.. After wheelin it hard a few weekends ago, i broke the hydro ram and my k5 was almost un-driveable trying to drive home. I got the ram back on and working now, and although much better, the only time i still get some deathwobble is at freeway speeds. /forums/images/graemlins/yikes.gif!
    I have played with several things, tightened up ubolts, made sure wheel bearings were tight, replaced my cracked shackle bushing, inspect kingpin bushings, adjust toe in so there is almost no toe in. (toe it out to compensate for bent tierod)
    ... this has helped but not eliminated my deathwobble.
    I ordered up a kingpin rebuild kit, and plan to install it this weekend... then remove my hydro ram and take it for a drive and see if its gone.
    Like i mentioned after beating my truck pretty good in the rocks, it is pretty much undriveable on the street without the hydro ram hooked up. I was getting deathwobble from every bump in the road between 15-35mph.
    I can't believe what a difference the hydro assist makes, with it on, it totally absorbs and masks the deathwobble until about 60mph. Hit a big pothole or bump and the frontend starts going crazy. /forums/images/graemlins/1zhelp.gif
  12. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Oh wait a minute, i'm sorry.... some of the guys around here HAVE found a fix for their Deathwobble on the street...
    ... buy a tow rig and a trailor.
    /forums/images/graemlins/wink.gif /forums/images/graemlins/ignore.gif /forums/images/graemlins/thinking.gif
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    so it somehow makes a difference who sets the toe in??
  14. 86chevybanshee
    May 15, 2004
    917
    beverly MA
    its amazing what taking air out will do /forums/images/graemlins/whistling.gif
  15. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    [/ QUOTE ] /forums/images/graemlins/wink.gif
    BTW, you running SX's or regular TSL's?
  16. backcountry
    May 27, 2004
    916
    MJ,
    LOL! /forums/images/graemlins/doah.gif Ok, take your truck to Kmart and have the front end aligned. /forums/images/graemlins/screwy.gif I'll take mine to a place that all they do is front end alignments and we will see. /forums/images/graemlins/smirk.gif
    Experence is everything. /forums/images/graemlins/thumb.gif Aligning a vehicle is easy however, troubleshooting problems such as yours is difficult and takes experence. /forums/images/graemlins/peace.gif
  17. Ryan B.
    Jul 18, 2001
    5,693
    CA
    I totally agree, when it comes to car algnments...
    For our trucks however, the caster and camber isn't really adjustable. You could put shims behind the spindle for camber or shims under the leaf pack for caster...
    But the only thing that is really adjustable is the toe in and most people should be able to get it close with a tape measure. /forums/images/graemlins/thumb.gif
    It would be nice to put yer truck on an alignment rack and make sure everything is within spec and if something wasn't that would explain the uneven tire wear on the front. /forums/images/graemlins/thinking.gif
  18. backcountry
    May 27, 2004
    916
    /forums/images/graemlins/waytogo.gif
  19. GORRILLA
    GORRILLA 1/2 ton status
    May 3, 2003
    315
    TX panhandle, out at the river.
    Not trying to start an argument, but I, (we), fixed my death wobble by over tourqing the u-bolts. Almost to the point that fear of snapping them came into play.
    I haven't had a problem with my 60 since.
    Since the kit is only $30, I had little worry about the u-bolts, I was more worried about a useless k5.
    Just an .02\
  20. great scott
    great scott 1/2 ton status
    Dec 31, 2002
    333
    Utah
    I replaced all the king pin parts and tie rod ends and still get DW. I have found that rocking the wheel to one side insted of mahing on the brakes temp stops it. so i to am now playing with toe.
