Death Wobble
Discussion in 'The Garage' started by bigbadchev84, Oct 4, 2004.
  1. bigbadchev84
    bigbadchev84 1/2 ton status
    May 17, 2004
    2,191
    Hermiston, Oregon
    i have a 84 blazer with 76 3/4ton running gear under it with an 8inch lift and 38.5 tsl sx swampers on it, when i try to drive it the passenger wheel wobbles like the lug nuts are loose, ive tried rotating tires, i changed the steering stabilizer, wheel bearings inner/outer and new race (both sides), and ive put new balljoints on both sides, still does the wobble i have to come to a stop then start driving again to get it to stop, it mostly does it after a corner or hitting a bump
  2. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    From time to time mine comes back, last time mine did this it was because the spindle nut had backed off a little and I had some play in my hub, this allowed the tire to "wobble".
  3. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
