Death wobbles revisited (AND THE FIX)
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric M., Aug 19, 2003.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    For the first time after 4 GM 4x4s, I am experiencing death wobbles (steering wheel shaking from left to right very violently) at about 35 MPH, with 33" BFGs on a 3/4 ton 10 bolt. I know this topic has been covered many times. I did a search and came up with only 2 posts. What other names does "death wobbles" go by ... I'm sure that isn't the official name.
    Thanks,
    Eric M.
    THE FIX 9/22/03
    So, the axle had new ball joints and tie rods already and I'd cleaned and inspected all the bearings and hubs. I looked for obvious play and installation problems with all the above and found nothing. I decided to replace the draglink. As I was replacing it, I noticed the rubber connector between the steering box and steering shaft was shot, and quite sloppy. I never even test drove the truck after installing the draglink, but instead went ahead and replaced the rubber connector. I took the truck out and guess what ... death wobbles ... still. Although the steering was much tighter and the wobbles were not as violent, I had obviously not corrected the problem, just eliminated some play which accentuated the problem. I then took the advise of one of the below posts and swapped the front tires with the rear. It's been 3 weeks now and not a single wobble. I have no idea what could be wrong with the tires, they work fine on the rear, they are balanced and in good shape with lots of tread. They're BFGs so you know they are well made. Anyways, wanted to post this so others doing a "search" for DW repairs will try swapping the tires before buying a new drag link .... anyone wanna but a draglink!? /forums/images/graemlins/crazy.gif
    Eric M.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Re: Death wobbles revisited
    <font color="green"> "Death wobble" is the most common term, and the fix for D60s was found to be either new kingpin springs or adding a washer on the top of the spring as a spacer to increase the preload on the springs. Also you want to make sure that the caster is in spec, I beleive at 8 degrees. It could be lots of other stuff, but if everything is in good shape as far as steering equiipment then the spacer or caster is where to go next. Of course, hydro assist gets rid of it nicely as well. /forums/images/graemlins/thumb.gif</font>
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Isn't this typically a problem only with kingpin axles like the D60 front?
  4. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Yeah, I think that death wobble is usually referring to a 60, but people have complained about it happening on the 10b and 44 also. Obviously it wouldn't be a kingpin problem...
    Have the ball joints and all the TREs and DREs been replaced? Tires balanced? </font>
  5. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    ive heard of death wobbles with all sorts of front ends, dana 30s too, balljoints could be worn to the point of causing it..check out the normal front end stuff that wears out..
  6. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Ball joints and tierods are new. I'm thinking either drag link ends or steering box, although both seem to have no play. Tires are balanced.
    Eric M.
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    How about the steering stablizer? I had death wobble on my 44, swapped stabilizer and it went away. I notice it comes back with my tires not inflated evenlly.
  8. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Steering stabilzer is new. I'll check the tire pressure.
    Thanks,
    Eric M.
  9. wrathORC
    wrathORC 1/2 ton status
    Apr 27, 2002
    908
    Hancock, MI
    Swap the tires to the back. The only time I've had a problem is with tires that wobbled/out of balance/out of round.
    I've run with worn out balljoints, sloppy draglink end near the steering box, and worn out center link ends and never had any wobble. Even when I ran for a year with a steering dampener that did nothing but look pretty.
    I've fixed everything but the draglink end near the steering box and the sloppy steering box. I still don't have a wobble unless I put bad tires on the front.
  10. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    I was thinking about swapping the tires front to back but thought that was a crazy idea. Glad to see someone else thinks like me too! I'll give that a try.
    Eric M.
  11. FWP
    FWP CRS
    Oct 11, 2000
    3,845
    3
    Prescott Valley, AZ
    Search for "death wobble" or "DW" here and on pirate. You'll be sick of reading about it after a couple hours /forums/images/graemlins/rotfl.gif
  12. NightRider
    NightRider 1/2 ton status
    Aug 13, 2002
    119
    Charlotte, NC
    I'm having same problem, but w/ a 10 bolt. And it does it rarely, ne other suggestions to try? I'll give my front end stuff a look @ and check my tire pressure.
  13. seattlek5
    seattlek5 1/2 ton status
    Feb 23, 2001
    311
    ...with one hand on the bender.
    I had this too when I rotated tire my tires (front to back, 38SX's) It would shake the whole truck starting at about 30 and would get worse the faster you went. Even got pulled over when it went into a wobble taking off from a stoplight with a cop next to me, scared the crap out him. The front end is completely rebuilt and caster has been adjusted with a 4-degree shim (longer shackles on the front springs) and a new stabilizer installed. Still shook. /forums/images/graemlins/confused.gif I've spent more time reading death wobble post here and on POR than I want to admit. /forums/images/graemlins/confused.gif /forums/images/graemlins/1zhelp.gif
    The fix (in most cases): set the toe to 1/16" toe-in, some people run a little toe-out. You may have to play around a little to find what works the best for your rig. Toe-in helps with stability. I was running about 1/4 to 3/8" of toe. This fixed it and with the rear being welded it tracks absolutly straight down the freeway. Hope this helps
  14. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
    SeattleK5,
    Reading your reply sounds exactly how my D44 used to act. I believe I tried everything I (and everyone else) could think of. Of course, hydro assist is the only reason my truck was driveable.
    I have since installed a D60 with the same hydro assist setup. I can sometimes still "feel" the wobble just want to start @ about 30 mph but is quickly dampened out by the hydro.
    Glad to hear that toe in helped you but I tried at least a dozen different settings with no change. Tires did not matter as well- 40's or 31's!
  15. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    I used to get this problem with my old 86' bronco with the independant dana 44. it would start shaking at around 30, but if i hammered it to 40 and above it would stop. The problem was a cracked frame allowing play in the steering. Which makes sense, if you dont have any play in the steering there should be no reason for the tires to wobble if your holding the wheel straight. Just my opinion. I would have someone move the wheel back and forth and check the entire steering system for play, including the frame for movement.
  16. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    See top post for fix.
    Eric M.
  17. Confedneck
    Nov 1, 2002
    5,236
    i saw death wobble today, from the next lane over..some scary [darn]..one ton crew cab truck, bone stock beater...wish i could get my hands on that thing..
  18. Greg72
    Mar 5, 2001
    15,684
    1,392
    642 Days to BB2018
    Eric,
    There is a difference between tires that are "balanced" and tires that are "round"....... /forums/images/graemlins/tongue.gif
    My 38.5 Swampers balanced to "0.0 oz" on the machine, but that only means that they are balanced across the tread. They are still "eggshaped" for sure.....
    I don't have full-on death wobble with my current setup, but there's a constant vibe I'm stuggling to cure. Moving tires from corner to corner makes a difference, and the tires I've grooved seemed more smooth.
    Now that I've FINALLY located a place that does "truing" I'm going to get my tires made ROUND once-and-for-all....! Then a re-balance, and we'll see what the final outcome is.... /forums/images/graemlins/thinking.gif
    I'm hoping for the best.
  19. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Greg,
    That's good to know. I thought balanced ment "balanced" even if tires were out of round. What's confusing is I've always thought BFGs to be one of the better brands out there, and 33" to be pretty small. I'd expect problems like this from a 36" Dick Cepek or Ground Hawg, but not a 33" BFG. I did buy these tires used from a friend. They were off a 2wd, so no damage, but the truck did sit a lot ... maybe they developed a flat spot.
    Eric M.
  20. 90blzr
    90blzr 1/2 ton status
    Mar 25, 2001
    3,027
    SO CAL
    Where did you find a place to true your tires? How much do they charge?
    Will they do it to used tires, or only new? /forums/images/graemlins/thumb.gif
