Deathwobble sucks. Fender washers rock.
Discussion in 'The Garage' started by Ryan B., Jul 27, 2005.
  1. Ryan B.
    Jul 18, 2001
    5,693
    CA
    Well i finally did it. Installed 2 fender washers under the kingpin cap (histeer arms) on both sides.
    I started getting deathwobble again last weekend on a good 100 mile drive. Right when it started happening, i inspected everything real close and i was convinced it was the Tie Rod End.
    So the next day i replaced it, same thing. I played around with toeing it in more little by little, then going back to slightly toed out, with no real drastic change in the Death wobble.
    So I finally tried the fender washer under the kingpin cap trick and it fixed it! only I shimmed it a bit too tight. So I tried taking one of the 2 washer out, WOAH! :eek1: DW came back! Found some other washers that were about half as thick.. put one of those back in each side, Deathwobble is gone. :wink1:
    I always thought of this as a band aid fix, but since this is my daily driver, i had to try something when i couldn't find anything else wrong!
    I suppose i should try installing all new bushings and springs again and see if that cures it. :rolleyes:
    I'm ready to get some of those WFO arms that eliminate the springs and use a solid spacer and shims. My friend got some of those and his truck has no deathwobble since installing em. My deathwobble always seems to come back every 4 or 6 months for one reason or another. WTF!?
  2. tRustyK5
    Jul 23, 2000
    36,169
    1,368
    E-town baby!
    The spring needs a certain amount of pre-load to keep the nylon cones seated on the king pins. Stock tires don't often exceed the preload, but the uber heavy swampers we run often do. New springs and bushings should help for a little while, but eventually the spring will lose some of it's height and consequently some of it's pre-load and DW will come back. The washers aren't a true band-aid, they don't mask the problem they fix it by adding a little more pre-load.
    Rene
  3. spincast375
    spincast375 1/2 ton status
    Aug 20, 2004
    194
    Tennessee, U.S.A.
    any pics?
    We've got DW. I do not understand where you installed these washers. Can you provide pics or more details?
  4. Greg72
    Mar 5, 2001
    15,681
    1,392
    642 Days to BB2018
    Maybe someone has located a kingpin spring replacement that has the same overall height but more spring pressure (lbs/in)???
    Valve springs would be nowhere near large enough (but that's the along the lines of what I'm thinking)...there must be something in a McMaster-Carr or Grainger catalog that would work????
    I wonder if Mogs get deathwobble? :D
  5. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your profile says you are running a D44 not a D60. Only D60 death wobble can be cured by the washer trick. D44's you basically need to figure out what the real problem is. It is usually one or more of these
    Frame broken behind steering box
    Worn tierod ends
    Worn balljoints
    Worn steering gear
    Do you have crossover steering? If so that can also help cause it if your steering arm is shorter then your pitman arm. Or if the nut under your pitman arm is coming loose.
    Warped brakes can also cause death wobble like symptoms under braking.
    Harley
  6. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    Anybody ever have problems with wandering steering after the fender washer trick? My truck tends to begin DW every couple thousand miles, so I add a fender washer and the DW goes away, but the wandering comes back. I've got 3 washers per kingpin right now, and each time I add a washer, my truck starts to wander until the spring relaxes a little, then there are miles of smooth sailing. Next time DW comes back, I'll just change out the springs and start the cycle over again.
  7. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
