Debadging??
Discussion in 'The Body Shop' started by badmix, Oct 23, 2006.
  1. badmix
    badmix 1/2 ton status
    Nov 7, 2004
    4,205
    60
    West Virginia
    I asked this previously in the garage. Got a lil bit of info. Basically I need to know how to get the emblems off the front fender and back quarterpanel off without destroying them. I pulled the taillight and still cant reach back there. Isnt there some kinda speed nut or something holding it on? How to get to it?
    thanks
  2. scasey28
    scasey28 1/2 ton status
    Aug 22, 2005
    105
    chico
    both sets of emblems are attached by two nuts. The rears should be pretty easy to access. However the fronts are almost impossible to get at. Im pretty sure that you'll have to remove the front fenders in order to get at the emblems. I went the east way and used tin snips to cut the fronts off w/o removing the fenders.
  3. badmix
    Nov 7, 2004
    4,205
    60
    West Virginia
    Well I couldnt get my hand anywhere near the rear ones, I figured the fronts were behind the fender. I may jus snip them, but id like to try and save em. Ill see.
  4. scasey28
    Aug 22, 2005
    105
    chico
    just a thought, you might be able to get to the rear ones, by removing the back break lights and housings. Since the rear fenders have dual layers.
    -scott
  5. badmix
    Nov 7, 2004
    4,205
    60
    West Virginia
    Already tried that, figured there would be room, there wasnt, I need to look a lil better I guess.
  6. Cmoe
    Cmoe 1/2 ton status
    Feb 19, 2000
    2,884
    Mesa,AZ
    Mine are just pushed into a clip that holds them in place.... It was this way one my 78 and also on my 87 tub/front clip.... I just used a rag and a screwdriver to stake mine off before I had it painted last time.....
  7. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    Yup, they run barrel clips quite often, not always a speed nut...
    I have no clue as to the year/manufacturer break down of it.. Maybe Chevy vs GMC? Pre 80? suppose it could be Plant location too...
