Decent cheap lockers?
Discussion in 'The Garage' started by Holeshot, May 20, 2006.
  1. Holeshot
    Holeshot Registered Member
    May 17, 2006
    9
    Minnesota
    Who out there makes some decent lockers that are pretty cheap? I have heard of the lock-right, detroit EZ and some others but I would like some opinions on them. The biggest tires it would see would be 35s and a 350 most likely.
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    what axle? different axles have different options.
  3. Holeshot
    May 17, 2006
    9
    Minnesota
    Ahh crap. I am an idiot.:o Its for a GM 10 bolt. I cant believe I forgot that little detail!:haha:
  4. rcamacho
    rcamacho 1/2 ton status
    Jul 1, 2004
    1,324
    WA
    Lockright works just fine in my 14BFF. Locker in a 10B might be an accident waiting to happen, especially with 35" tires.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Avoid Detroit Ez or Quic Loc ( Detroit Ez in 4wp house brand ) . Get a Powertrax Lockright or no-slip :thumb:
  6. Holeshot
    May 17, 2006
    9
    Minnesota
    Yeah as far as a 10 bolt being a problem, the truck just has 31s but may see bigger tires in its future. I think maybe a 14 BFF might be the thing to do. I am not sure though. Thats why I was looking at cheap lockers rather than something expensive. The truck probably wont see bigger tires for a while and if/when it does have problems I would probably throw in a 14 BFF and maybe put the locker in the front. So is a lockright the best thing for the price really? And how long would it take to install? Thanks guys!
  7. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Newbie a couple hours . After the forst couple times its cake . I do mine every six months to inspect it . Easy .
    Also get some Redline shockproof oil , it sticks to the metal components very well .
  8. MT wheeler
    MT wheeler 1/2 ton status
    Nov 14, 2005
    197
    Billings, MT
    X2 I broke 4 E-Z lockers in yrs with only running 33's.
  9. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    LockRite in front, NoSlip in the rear in a DD Burb. Use premium lube.
  10. MattK
    MattK 1/2 ton status
    Jan 12, 2005
    1,713
    Dallas, TX
    ive got a lockright in my front 10b and i love it. it was only like $220 and a simple install.
  11. CB77GMC
    CB77GMC 1/2 ton status GMOTM Winner
    May 6, 2005
    771
    Heath Springs, SC
    I have run 2 Powertrax Lockright's for a year now 10BF/12BR with 35/15.5's and no problems.
  12. 91jimmy
    91jimmy Registered Member
    Oct 17, 2003
    20
    I run a powertrax in the rear and a lockright in the front on 33" and it works great
  13. Holeshot
    May 17, 2006
    9
    Minnesota
    Sounds like lockright it is then. Where is the best place to buy one? :confused:
  14. MattK
    Jan 12, 2005
    1,713
    Dallas, TX
    got mine from summitracing.com.
    they're fast, cheap and sent me a free hat lol.
  15. southernspeed
    Dec 24, 2003
    4,395
    50
    VA
    I run a lockright in a 12blt with 35's. Haven't put it to any real test yet but it seems to work well. Bit of a pain on the street and not too nice for a daily driver. It's quite noisy even if your careful with the throttle in a turn. Try to pull out of a side road a bit quick and you'll have a howling tire behind you!
    I was going to put one in my DD too 'cause they're cheap but I don't think I could live with the noise and tire wear so that'll be getting a lsd.
    Lockright are cheap and real easy to install.
    One heads up for everyone using them though.: I checked my cross shaft for hardness as they suggest and it was indeed hard. Couldn't file or cut it. After 400 miles I pulled it out as I wanted to change my brake plates and there were bad indentations on the cross shaft.
    I spoke to Lockright and they said I needed one of their hardened shafts made for this application. They didn't make special shafts when I bought my locker so I figure they've had a lot of problems with wear so made a shaft for it.
  16. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Yea Mark, when I bought my NoSlip, it was with a hardened shaft. That was a 10b rear. LockRite for the front 10b didn't require any special shaft. Maybe they had already fixed that. BTW, they both work great.
  17. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Last time I bought a locker for a 10b jegs was the cheapest by a couple of bucks
