Decent High Amp Altenator
Discussion in 'The Garage' started by TrcksR4ME, Oct 12, 2002.
  1. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    I would like to upgrade my stock 63 amp unit to a high output unit. I do not want to spend a fortune though. I see 4WPW has "Powermaster" units that are 140 amps, for less than $200. Would this be an ok unit, or is there something else I should consider? /forums/images/graemlins/1zhelp.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    JEGS sells hi output 1-wire amps in different ratings.
    I got a 100 amp 1-wire unit for $90. Works great. If you need more amperage, they sell those too.
    -- Mike
  3. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,141
    14
    Bangor,Pa
    i got my 100 amp from summit for 100 dollars shipped to my door.works good so far.we;ll see how long that lasts when i get it wet mud boggin and puddle hoppin
  4. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Just out of curiousity, how does a one wire altenator work? I have wondered this for a while, my current unit has a plug with 2 wires and the wire off the back.
  5. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Also...how many amps is enough? I currently do not run much, no stereo or winch, some off-road lights. I would like to upgrade to something that would be powerful enough once I do add a winch, etc.
  6. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    A one wire alt. Uses a self exciting regulator. It will "turn on" when engine RPM is about 1500 to 2000. It is the same as a regular alt. with a diffrent regulator is all. They sell the regulators at NAPA, if you ever wanted to convert one to this set-up.
    I rember there being a rebuild kit for High amp alt. somewhere. I'll have to rember that later. Anyhow I use a factory 94 amp. GM alt in mine and never needed more. I got it from a place in Bellevue, R&L they have starters and alt, generators even. /forums/images/graemlins/grin.gif
  7. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    www.wranglernw.com has excellent quality units............have one myself. /forums/images/graemlins/thumb.gif
  8. thebigdaddyof2
    thebigdaddyof2 1/2 ton status
    Dec 28, 2000
    2,053
    St. Louis, Missouri
  9. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I used to rebuild Altenators for a living. The 7127 (GM inturnal reglator) is very easy. You should be able to find an Altenator rebuild shop in your area that could put together a High Amp unit for you. We used to sell them for $68.00 or build yours up for $25.00 if memory is correct. I'd look into that befor buying a new unit.
  10. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    At this point it would be easier for me to order a new one and keep the one I have now as a spare. Not much time right now to find a shop and take in etc, thanks for the suggestion though.
  11. TrcksR4ME
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Think Im gonna go with that one too. Seems to be the best price I can find and sounds to be of decent quality. Thanks
  12. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I got mine from the local parts store for a 1 ton chevy with BB and all the power stuff. Stock is 95 amps. Around $80 bucks with a lifetime warranty.
