Decided To Run 38's under 4" Susp. 3" Body and cutting!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BorregoK5, Nov 26, 2001.
  1. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Decided To Run 38\'s under 4\" Susp. 3\" Body and cutting!
    So I've decidided to keep the 4" Rancho lift as its doing me well so far. I'm going to put on the 3" body lift this weekend (unfortunately missing the So.Cal Miller Jeep Trail Run) and get the truck ready for the 1 ton gear & 38's. Is anyone out there have pics of a 4" suspension lift, 3" body lift and 37-39" tires? I'd like to get an idea of how much cutting I'll need before I commit as its going to be heafty.
    I started with nothing and I still have most of that left! - <a target="_blank" href=http://www.echobit.com:81/k5/> Pictures</a>
  2. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    Re: Decided To Run 38\'s under 4\" Susp. 3\" Body and cutting!
    way to go mike hack that sheetmetal !
    dents ....
    O R D's axles
    NO BREAKAGE :)
  3. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    I have 4+3 and 38x12.50"s. You are going to have to cut a lot. Mine are trimmed and they still rub. If you go with 16/38.5 or 38.5x14.50, you are really going to have to trim a lot. If you're not scared to hack away, then you should be straight, but I would recommend 6+2 with trimming rather than 4+3.
  4. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Andy - You kow it! I've ripped these 33's up so bad I can't get them balanced. I'm ready to step up a few notches but want to keep the low center of gravity.
    RedDwarf, ironic that you mention the 38.5x14.5 as that was my intetnion. I'm not too worried about cutting as long as I can make it look presentable. I'm concerned with the foot wells from the cab. How much cutting did you do and how bad do you rub (any tire side lugs ripped off?)? I was going with a 6" susp + 3" body but I'm really happy with the ride on my 4" setup now.
  5. RaisedK5
    RaisedK5 1/2 ton status
    932
    Long Beach, CA
    Ok i have a 6 + 2 plus 36' ers and the only way i got it to stop rubbign was to do a Steve Fox Style trim job, and i think i still barely kissed the inner fender at the back with an edge lug on our last trip, of course the shock bottoming out kept it from getting too bad, but if i trimed that much have an inch more lift and inch less (radius) on the tire, then you're gonna have to trim a bit more than i did. I'll see if i can get my pics developed and email you a couple but i'm not promising, or you can drive out and check out my ride this weekend.
    Leland aka RaisedK5
    "Of all the things I've lost, I think I miss my mind the most!"
    "Are the voices in my head bothering you?
  6. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    What about the ORD 1" add a leaf front and rear. It would give you the 8" lift your looking for with the 3" body lift. Keep the 4" you have now, add the 1' and the 3" body lift. It would be cheaper then new springs, and you get to keep your good ride. Just a thought.
    My Chevy isn't broken, its just out of gas.
  7. Gold Rush
    Gold Rush 1/2 ton status
    1,498
    I have 36X12.5X15 Swampers and only a 4" lift. RockBlazer has 38X14.5X15 Swampers and 4" lift and we both have lots of travel. Click on the link below for my site and RockBlazer has pictures on his club website at http://www.extremeblazer.com
  8. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I am getting ready to do 38.5"s on the 4" lift. Well at least once the burb is finally up and going.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  9. elkboy
    elkboy 1/2 ton status
    Aug 18, 2000
    293
    Hillsboro Oregon
    <a target="_blank" href=http://photos.yahoo.com/bc/nepatten/vwp?.dir=/Project+K5&amp;.src=ph&amp;.dnm=done2.jpg&amp;.view=t&amp;.done=http%3a//photos.yahoo.com/bc/nepatten/lst%3f%26.dir=/Project%2bK5%26.src=ph%26.view=t>http://photos.yahoo.com/bc/nepatten/vwp?.dir=/Project+K5&amp;.src=ph&amp;.dnm=done2.jpg&amp;.view=t&amp;.done=http%3a//photos.yahoo.com/bc/nepatten/lst%3f%26.dir=/Project%2bK5%26.src=ph%26.view=t</a>
    4" suspension , 3" body, minor fender trimming [​IMG], 39.5's, no rubbing.
    <font color=red> Elkboy </font color=red> 82 K5 fuel injected H.O.305, TH350/205, 14bolt/10bolt and 39.5 TSL's.
  10. lax037
    lax037 Registered Member
    May 29, 2001
    49
    Long Island
    I have only a 4" lift, and i'm running 42's, don't worry about your foot wells
  11. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    YOU CALL THAT MINOR?????????
    Tim
  12. K10ANDYKHAMNIC
    Sep 17, 2001
    1,962
    Western CO
    yo chill , not everybody worships their sheetmetal ;) j/k
    dents ....
    O R D's axles
    NO BREAKAGE :)
  13. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Elkboy, thanks for the pic post. It seems to me that the trick to all this is getting the offset in the rims to exactly compliment the wheel wells. Can you give me a bit of info on your rims (size, backspacing etc.. if possible) as well as tires (are those swampers?). I think the fender trimming is within acceptable limits on your truck and it looks good.
  14. RedDwarf
    May 9, 2001
    816
    Hey Elkboy, looks pretty good.
    I haven't ripped off any lugs yet, but I did get a couple slices in the sides from fresh-cut metal. I cut more, but they still rub the rear of the front fenders. Gonna cut or lift more one of these days....
  15. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    <blockquote><font class="small">In reply to:</font><hr>
    <hr></blockquote>
    You gotta show us some pics!! How much of your sheet metal is still there?
    Rod
    Alameda, CA
    85 K5 6"ProComp 35"Boggers 14Bolt/ Dana44 4.10's
    <a target="_blank" href=http://coloradok5.com/gallery/K5Jungle>http://coloradok5.com/gallery/K5Jungle</a>
  16. BorregoK5
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    I'd imagine the hood, the cab and the shell might still be intact or its sits level on the bump stops.
  17. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Well I know a Blazer that has a 4" lift with the extended ORD shackles and a zero rate add-a-leaf for a grand total of 5" lift and he runs 37's. The sheet metal wasn't butchered either. WHO......you ask? It goes by the name of UAV. That's Steve's setup and his truck looks good and is very funtional. That's the setup I'm going for in order to run the same 37's.
    <font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
  18. lax037
    May 29, 2001
    49
    Long Island
    As soon as i figure out that picture thing, i'll post em
    all the sheetmetal i cut out was rotting anyway, so i figured cut away. it doesn't look that bad, a little overboard in the rear sheetmetal, and those rear fenderwells had to go. it was still able to flex though
  19. jekbrown
    May 19, 2001
    45,032
    366
    Vancouver, WA, USA
    It wasnt "butchered", but the UAV has definitely had a pretty good trim. =p
    Jason
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  20. Esteban86K5
    3,712
    Bakersfield, CA
    Yes it has, but it looks good. It's not an eye soar.[​IMG]
