Decision Time
Discussion in 'The Garage' started by 78 k5, Aug 23, 2005.
Best $1,000 (Read post first)
  1. D60
    10 vote(s)
    19.2%
  2. Tires
    42 vote(s)
    80.8%
  1. 78 k5
    78 k5 1/2 ton status
    Jul 8, 2004
    261
    Auburn, AL or ATL, Ga
    I've got $1,000 to spend and I can't decide what to do. I'm debating between a D60 and new tires. The tires on my truck are absolute bald crap but my 10 bolt is equally crap. I do a little trail riding but mostly Alabama mud. I'm only pushing the axles with a tired 6.2 diesel so I'm leaning toward the tires and the 60 later on. What would you do?
  2. dyeager535
    26,980
    No matter how beefy your components are, you won't be able to use them if your truck can't move. :)
    BTDT, good tires are night and day from bald ones. I'd say that difference is as big, if not bigger, than 2WD to 4WD!
  3. muddyblzr
    muddyblzr 1/2 ton status
    Nov 2, 2004
    623
    houston/san antonio texas
    i vote for the new tires. when i got new mud terrains it was nite and day difference especially in the mud. the dana 60 is definetly something you will want also but the new tires will help more places than just offroad
  4. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    if you got a good deal on a d60 then go for that. I found mine for $400 so I jumped on it 30 min after calling the guy (took the afternoon off fomr work even). Tires are always around the same $$$ onless you got a line on some good used ones. Whatever the better deal of the moment is I would go for that. You can always buy decent used tires cheap too till you can afford new ones again. Different thoughts to consider anyways. :crazy:
  5. Kiwi John
    Kiwi John 1/2 ton status
    Jun 24, 2005
    249
    West Sussex, England, U.K.
    Tyres!
    $250 per corner is going to get you some Big Boots i think?
  6. 78 k5
    Jul 8, 2004
    261
    I'm first in line for some 39.5 Iroks (95%) and I've also got a solid deal from interco for 38.5 boggers ($850 :D ) and no d60 prospects so I'm thinkin tires too. Thanks for the input, just wanted to make sure I'm making the right decision
  7. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Heres the way I see it, the dana 60 is a nicety you don't have to have it, the tires you have to have, so see if you can follow my logic here get the 60, cause you will figure out a way to get the tires cause you gotta have them. :D
  8. Brocky
    Brocky 1/2 ton status
    May 22, 2005
    1,170
    St.John's Newfoundland, Canada
    I second that one. Go with the axle. Your gonna need tires so go with the axle and force yourself to work on getting money together for tires. :D
  9. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Bigger, fresher tires are just going to help you break that 10-bolt more effectively.... :D
    You can always buy a cheap, used set of tires, or military surplus tires for maybe $200/set. The same can almost never be said about a D60.
  10. NerdBoy
    NerdBoy 1/2 ton status
    Dec 24, 2002
    429
    Southern Illinois
    If you mostly do mud, I don't see the point of a beefier front axle. Adding more weight up there will help you sink faster, and the difference in size would tend to push more mud, I would think. I was always under the impression that getting a D60 was most useful when you were in places that you really needed to crawl, so it could handle to torque when you got caught up.
    I would go for the tires, mostly since they will allow you to get through the mud. You won't be mudding without the tires, but you will be mudding without the D60.
    Besides, if you *do* happen to break the 10-bolt, you can find replacement parts for cheap.
  11. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'd have too get the Dana 60 front axle. Cheap used tires will get ya by for now, but a 1/2 ton axle won't hold up to large tires very long. By the way, I've seen mud and 36's kill Dana 44s and 10 bolts.
  12. Chaddy
    Chaddy 1/2 ton status GMOTM Winner
    May 23, 2005
    4,110
    Salt Lake City,Utah
    got mine for 400$ as well so if you look you could get one for less than a grand then have $$ left over to help buy new rims for the 8 lug set up
  13. MTMike
    MTMike 1/2 ton status
    Feb 10, 2005
    2,992
    Billings, Montana
    D60.
    Thats more of a "would like to have" item and is much harder to pass by the wife when you don't have the extra cash. Tires are a "must have" and are easier to force passed the wife.
    Mike
  14. Brocky
    May 22, 2005
    1,170
    Someone here uses the phrase fix it before it breaks. Words to live by. Have a look around. One of my buddies scored D60, 14bff with 38's for $1400. He bet me too that one. :mad: But I just found my axles, sitting under a k30 in the woods. :bow: Don't rush into it, have a good look around.
  15. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    If its one or the other, you have to have tires. You may look around and find both for $1000.
  16. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    Not in the mud I run cause you gotta have big tires if you wanna play in the deep holes and big tires snap axles
  17. crazyhole812
    crazyhole812 1/2 ton status
    Jul 6, 2005
    228
    missouri
    go with the tires and romp it til it breaks
  18. resurrected_jimmy
    May 23, 2005
    2,241
    back home in Houston
    I played that game when I was in school, I ended up with a locked and regeared 14FF, turns out it doesn't help if you have no traction, end result was a wrecked burb from bald tires on a wet curve.....
  19. 4trolls
    4trolls 1/2 ton status
    Nov 13, 2002
    190
    vancouver wa
    Ive had my 39.5s on my dana44 front for a year with no problems. I say get the tires
  20. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    get tires first
