Decisions....decisions
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by stock93, Jun 27, 2004.
  1. stock93
    stock93 Registered Member
    Feb 18, 2004
    68
    Huntsville, AL
    I'm trying to decide what to do with my truck. The axles seals went out in my 10 bolt front end. I tore it down and I need ujoints, seals, all bearings, brakes, and the spindles themselves had stripped the threads. I'm running 36s so I'm very hesitant to put $500 into the 10 bolt. I need to regear to 4.56 anyway. I have a 4.56 14bff thats not installed due to the gears not matching. I definately want to put this axle in but cant right now due to the gearing. I've been trying to find a dana 60 but everyone wants at least $1500+ for one plus regearing. Being a student I just dont have that kind of money. Do you guys think it would be worth while to find an 8 lug 4.56 geared 10 bolt? Should I just wait until I can afford a dana 60? Just put the 10 bolt back together and not mess with it right now? Its pulling steady jackstand duty right now and I really need to be able to drive it.
    John
  2. J.R.
    J.R. Guest
    i would look for a dana44 and use your 8 lug setup.. unless you are really wheeling it hard no need for the dana60
  3. ugly_blazer
    ugly_blazer 1/2 ton status
    Apr 12, 2004
    1,214
    I would look for a 4.56 8-lug 10 bolt or dana 44. You should be able to get one for less than the $500 that you say it will take to rebuild what you have, then you will not have the expense of re-gearing. A 10 bolt or d44 will be fine with 36's as long as you are not very abusive.
  4. mtn. burb
    mtn. burb 1/2 ton status
    May 13, 2004
    1,260
    Ojai Calif.
    Hmmm, your in 'Bama. I have an 8 lug, 10 bolt w/ 4.56 gears, open, new Warn hubs, it's ready to go. It's complete. Out of my 'Burb. I'll P.M. you.
