Decisions decisions
Discussion in 'Audio' started by Muddytazz, Jan 6, 2006.
  1. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    How would be the best way to do things.
    Currently my head unit is controlling 4 sony explode 6x9's (1 in each door of the burb). I installed a 4ch amp and 2 subwoofers also now.
    Would it be better to just leave the 6x9's connected to the head unit and the subs on the amp or run everything thru the amp?
    Amp = Volfenhag ZX-7160
    6x9's = XS-V6933
    Subs = Pyramid PNW10590 10"
    And I don't want to hear about getting new stuff, cause I'm using this stuff until I can afford something better.
  2. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Whats the power and impedance specs for the amps and subs? This will definitely affect your decision, as it affects how the subs are wired, and how much power is distributed to the system from the amplifier.
  3. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Max power output 1000W (250W x 4ch) @ 2ohms
    Power Output
    340W (85W x 4ch) @ 2ohms
    200W (50W x 4ch) @ 4ohms
    Bridged power 170W x 2ch @ 4ohms
    2 ohm stable
    Tri-mode capable
    Fan Cooling
    Variable Bass Boost: 0 - 18dB
    Variable Bass Frequency: 30Hz - 100Hz
    Channel Seperation: >60dB
    Signal to Noise Ratio: 90dB
    THD 0.03%
    Frequency Response: 20Hz - 20KHz
    HPF: 50Hz - 1KHz
    LPF: 30Hz - 250Hz
    Adjustable Sensitivity Range: 0.1V - 1V
    Input Impedance: Low Level (10K Ohms)
    High Level (100 Ohms)
  4. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    Use your 4 channel amp for the explodes and another amp for the subs.
  5. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    If I would I could, but this is what I've got to work with now.
  6. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    And the impedance of your subs?
  7. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    All I can remember off the top of my head right now is.
    Peak: 1000W
    RMS: 500W
    4ohm
  8. chevyin
    Sep 14, 2005
    1,324
    Pismo Bch CA
    Well, with dual 4ohm subs you can either wire them up to two channels of your amp (leaving two open for 6x9's), but that would only send 50watts to each sub. Just bridge the amp and run each sub to the bridged channel. That way each sub will see 170watts.
