Decoding my motor.
Discussion in 'The Garage' started by broncoman6524, May 14, 2006.
  1. broncoman6524
    broncoman6524 1/2 ton status
    Oct 31, 2005
    2,469
    chuluota Fl
    Alright i tried searching here and google with no luck and its startin to piss me off. Im wanting to build a stroker out of a 350 that i had in my backyard. I went and pulled all the numbers.
    On the back it says
    GM 5.7LG SGI
    J282
    14093638
    Then from the front of the engine infront of the right head V1103UKA
    could some one please help! Im trying to figure out what year this block is.:mad:
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I'm not of much help right now but i could look it up tomorrow or you can check it out on mortec.com. Unless you are just wanting to know what year the block is for your own reference it really doesn't matter other than 1985 and earlier are a 2 piece rear main seal and 1986 and later are a 1 piece rear main seal engine which is really your only concern with maybe the exception of driver or pass dipstick if it is an early engine.
  3. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    Here is what your engine is:
    14093638...350...87-95...2 or 4...Roller or flat tappet cam, one-piece rear seal
  4. broncoman6524
    Oct 31, 2005
    2,469
    chuluota Fl
    The kit i was looking at says up to 85 and accoring to mortec it says my block is a 14093638...350...87-95...2 or 4...Roller or flat tappet cam, one-piece rear seal
    So i guess that means im looking into a different kit.
  5. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    yep, you have the 1 piece rear seal block which is 1986 and later. You can verify this yourself by looking at the back of the engine with the flexplate off and you should see an aluminum adapter plate bolted to the back of the block which has the rear seal in it.
  6. 1-ton
    Apr 17, 2004
    2,890
    169
    Las Vegas, Nevada
    At least you can put a roller cam into your engine, I believe.
  7. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Not all of the 1986 and later blocks are set up to directly accept the roller cam.
  8. dave_90_blazer
    dave_90_blazer 1/2 ton status
    Jan 1, 2004
    688
    Melvindale, Michigan
    J282= block was cast Oct. 28, year ending in a 2 (likely 1992)
    14093638= Flint engine plant, machined Novenber 3rd
    all this fits the 86-95 year range
    to be sure, look at the reat of the crank, if there is a aluminum plate surounding the end of the crank, and it holds the seal, plus, the rear of the crank(where the flywheel/flexplate bolts) is round, all this fits, so, figure its a 92 350
