Dedenbear Knuckles
Discussion in 'OffRoad Design' started by SF87K5, Feb 3, 2004.
  1. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Stephen How much are these?
  2. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Bare knuckles are $259 each, spindle stud kits are $18.00 per side (6 studs), High Steer arms are $300 for the pair, and the studs for the top of the knuckle are $10.00 each. The $10.00 studs are GM studs with the larger center section to index the arm tight before you even put the tapered nut on it.
    Is it considered bling if it's pretty AND works? If so.......Let the Bling run free!
    All our crossover or high steer arms are now like the one in the pic, 5 holes for the knuckle and 2 holes in the front of the RH arm, one for the tierod, one for the draglink. If you don't have Dedenbear knuckles, you just don't use the 5th hole.
  3. Bullet
    Bullet 1/2 ton status
    Mar 14, 2001
    1,222
    Abilene, Texas
    But can you get the knuckles with 4 studs, meaning that I already have the cross-over setup with 4 studs.
  4. bshewmaker
    bshewmaker Registered Member
    Sep 11, 2003
    79
    Arkansas
    Do those come without the tierod mount?
  5. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    The 4 holes in the arm you have line up with 4 of the 5 studs in the new knuckle. You just don't install the 5th stud in the knuckle.
    Eric M.
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    OK, 4 of the holes are the stock pattern, you just don't use the 5th hole unless you have the Dedenbear knuckles.
    If you don't want the tie rod arm, you our we could cut it off, but they're all cast with the arm on there to start with.
  7. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you put your x-over arms up for sale for almost what new cost then you buy new ones. or maybe stephen will cut you a deal for if you want to go to the DB knuckles. there would be little point going to the DB knuckles and not use the 5th stud.
    im thinking about this setup, but at just over a grand with shipping it will be a while before i decide if im going to do it or not.
    Grant
  8. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Someday i will get them, I got one of the early runs when Stephen added the 5th hole so my ORD arms will work fine.
  9. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Dedenbear does include the dimensions for the 5th hole so as long as the shape of your arm allows it, you can drill the new hole yourself if you want. If you have one of our arms, we can put the 5th hole in it here if you want, it'll run about $20.00 altogether but it's not a huge deal to do it.
  10. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I have the 5th hole, thats what I meant, I got mine right after you added the holes.
  11. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Yeah, I'd kind of aimed that at the guys above, and to make it known that we can do it.
