deep cycle battery question...
Discussion in 'The Garage' started by jekbrown, Oct 3, 2003.
  1. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    I have been reading a bunch of old posts (searching is so handy) about battery technology and I'd like some kind of definitive answer to the following question: is it ok to use a Optima yellowtop D31A as the lone battery in a DD/trail rig? basic battery stats...
    Volts: 12
    Amp Hours: 75
    CCA @ 0° F: 900
    CA @ 32° F: 1125
    J240 Life Cycle: 10-12,000
    Deep Cycles: 350
    Reserve Minutes: 155
    some posters in the threads I searched indicated that deep cycle batts like this shouldn't be used in constantly-charging type situations... which just seems weird... I mean, do you have to kill these batteries every single time you use 'em just for it to work correctly? why? good solid/factual info/experience appreciated...
    j
  2. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    I've been using a pair of blue tops on my seldom-used toyota for a few years now. They used to drain down just sitting until I put a switch on the battery ground cable. Now it sits for a couple months and I flip the switch and it fires right up.
  3. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    If you go to the optima web site and check their fact sheet you will see they list the yellow top as a type of hybrid starting/deep cycle battery. It is made to have enough ca to start your vehicle yet still function as a deep cycle. It isn't as effecient as a red top for starting or a blue top for deep cycle work. But it is a good compromise between the two.
  4. KShortell
    KShortell Registered Member
    Jun 11, 2001
    44
    Bel Air, Maryland
    Well, being a boater and a USCG Aux. vessel examiner, maybe I can take a crack at this one. A deep cycle battery won't give you high cranking amps. While they will take larger swings in charge than your typical starting battery, they just won't give you the kick you want or need for starting a V-8 in cold weather.
    This is why you'll typically see a dual battery setup in larger boats and RVs: one for starting (high cca) and one for accessories, etc. (the "house" battery).
    Hope this helps a bit...
  5. scrappy88
    scrappy88 1/2 ton status
    Mar 14, 2003
    314
    Loveland, CO
    If you go with the Optima D31 series, make sure you measure for it first. That battery is absolutely huge (physically) compared to the standard batteries in our trucks. I was going to go with that one but couldn't fit it under the hood without quite a bit of mods and a custom battery tray. Of course if you're mounting it in the bed you're all set. /forums/images/graemlins/thumb.gif
  6. dyeager535
    26,975
    How is it weird? Do you follow the premise that killing a "regular" car battery constantly is going to damage it? If you can understand or agree with that, then you have to agree that a battery not designed for constant charging won't work well in that application, or at least not as well as one designed for it.
    Same thing as with NiCD batters vs. Li-Ion. One has memory, one doesn't. One should be drained low consistently before a recharge, one it doesn't matter, as it's type of construction allows that.
    Different types of batteries require different care and usage.
  7. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    starting: is starting such a big deal when you have a good gear reduction starter on your rig? Seems like a batt that can put out over 1000 amps shouldnt have a problem with a starter... but I dont know crap about this stuff so... I dunno. /forums/images/graemlins/confused.gif
    cold weather: dont have much of that around here... portland/vancouver is about is mild as weather gets... never to hot, never to cold. Wouldnt a nice (mean green etc) gear reduction starter help with this also?
    size: yeah the dt31 is a huuuge sucker, heavy as hell too. It'll be custom mounted in the rear of the rig though, so there oughta be plenty of room for it.
    dyeager: yeah, i see what you're saying.. i guess it just struck me as odd to have a automotive battery that wasnt appropriate for automotive use (on its own anyway). I dunno, Optima says the yellow top is capable of both.. and it seems like plenty of people run sole yellow-tops. Im just looking for info before I sink lots of $ into a battery. I really dont want to mess with a dual mattery setup for various reasons... it costs extra $, takes up more room, requires some extra wiring etc etc. What I'd like is one great battery that would do everything I want (lights, stereos, light/moderate winching etc) as opposed to two joe schmoe batterys and a dual batt system for the same task.
    j
  8. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    This wont be much help, but...
    I have been using the Pro-Comp Deep Cycle/Off-Road battery. I am not sure if its a hybrid or not, but this battery has worked much better for starting than any other battery I have owned. The thing never goes dead on me either , which is more of truck wiring thing than battery. All I know is I get strong starts every time, even when it sits for a while.
    Now with that said, I doo not DD my truck, so it doesn't see everyday use, ever. Then again it is also an Exide battery and from all accounts from this site these are crap and the battery should stop working any time /forums/images/graemlins/wink.gif
  9. jekbrown
    May 19, 2001
    45,030
    362
    Vancouver, WA, USA
    yeah, i dont really DD my truck right now... and if I need to for work, it prolly wont be long before I get the $200 1981 escort to use for commuting.
    j
  10. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,137
    14
    Bangor,Pa
    i have a red top for my dd/trail rig.it works a hell of a lot better than my wallfart battery i had in there before.i also upgraded to a 100 amp summit alternater.
  11. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    Just a regular old battery works fine for my mild 305 and stock starter. I think my alternator is workin pretty good tho cause when I got the batt could only turn the truck over for like 3secs at a time. After like a day of driving around, she was full powa!
