deep cycle marine battery? will it work
Discussion in 'The Garage' started by the excuse, May 16, 2004.
  1. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    can i use a deep cycle marine battery in my blazer? i donnt really understand how the deep cycle batries work. right now somethimes when i have my brights on and i try to roll up the windows there is a major shortage on battery juce. everything starts dimming and brightens as the alternator turns over. i have to shut off the lights in order to put the windows up. the alternator seems new too, its much shinier thatn the rest of the engine bay.
  2. unclematty
    unclematty 1/2 ton status
    Jan 24, 2003
    3,164
    SLC UT
    deep cycle means that it can be drawn upon heavily without causing permanant damage , it can be discharged many times without damage. A heay duty alternator should be used in conjunction with a deep cycle. as to your problem I would say check out the output of the alternator , maybe a smaller diameter pulley on it, or turn the engine idle up slightly, or maybe your window regulators are drawing too much amperage, check the alternator first. hope that helps /forums/images/graemlins/waytogo.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Deep cycle batteries are not made for engine starting.
    I wouldn't run one as a primary battery.
  4. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    Its not that its not recommended. There's no problem with doing it. Its just that the deep cycles cant discharge enough out that is needed during starting- to properly size the same CCA's out of a deep cycle as a standard car batt, you would need almost a 75% increase in battery size. Hence, it dont fit in most engine bays. /forums/images/graemlins/smile.gif
