Deep Cycle?
Discussion in 'The Garage' started by Confedneck79K30, Feb 10, 2007.
  1. Confedneck79K30
    Confedneck79K30 3/4 ton status
    Oct 1, 2006
    5,384
    LA
    is there any use for a deep cycle in a pickup? like to use to run a winch, or welder?
  2. RockinChevy
    RockinChevy 1/2 ton status GMOTM Winner
    May 9, 2005
    2,313
    Chandler, AZ
    Deep cycle is a good way to go, keep it separate from your primary so you can still start the truck. I have an Optima yellow top wired to my Viair air compressor and will be wired to a winch and other stuff.
    Can run it dead and still charge up all the way and run it again...
  3. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    i pulled one outta my freightliner, and replaced it, i think i may use it in my pos...
  4. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I finally switched to a yellow top after killing 3 redtops in my blazer.
    It's worked fine as my primary for a few years now.
  5. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    what size battery is it, if it came out of a Freightliner?
  6. onetonbb74
    onetonbb74 1/2 ton status
    Dec 1, 2005
    2,083
    Campbell, CA
    ive got a yellow top, perfect for a truck/wheeler. Not high compression so cca doent need to be high, has like 56 amp hours so camping with lights and a radio going the whole time is doable. Sealed battery so no contamination or leaking, If you dont drive the truck for a month, it will still turn over no problem. Runs my winch no problem even with the truck off. They slow charge exceptionally well. If you daily drive your truck with a high compression motor, then id go with a red top for the cca or ca that are demanded.
  7. Confedneck79K30
    Oct 1, 2006
    5,384
    LA
    1035 marine cranking amps...
  8. RockinChevy
    May 9, 2005
    2,313
    Chandler, AZ
    pretty good sized battery! make sure you get it isolated and still charges off the alternator. :thumb:
