Defrost controls---NEED HELP
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BURBIN406, Dec 10, 2002.
  1. BURBIN406
    BURBIN406 Registered Member
    Nov 17, 2002
    17
    New Jersey
    My defrost stop blowing out ducts and only comes out of the dash vents not at the windshield where needed. We just had 8" of snow and are calling for ice and rain tommorow and I will need defrost, Any Quick Fix Ideas?
  2. Michael
    Michael 1/2 ton status
    1,576
    Sherman, Texas
    There is a little door inside that directs the air to the appropriate places. Sounds like the actuator (either vacuum or mechanical) poped off or is out of adjustment.
  3. BURBIN406
    Nov 17, 2002
    17
    New Jersey
    Thanks, I'll check the cable or vacuum ball under the hood.
  4. 83bowtyblazer
    83bowtyblazer 1/2 ton status
    Jul 29, 2001
    132
    Ft. Dix, NJ
    I had the same problem...the line was popped off of the ball underneath the hood. It should have a hard vaccum line with a soft rubber hose at the end if it. Just hook her back up the the under side of the ball.
  5. BURBIN406
    Nov 17, 2002
    17
    New Jersey
    Well it wasn't the hose. So I pulled the dash apart and didn't find any bad hoses. I checked the vacuum selector switch on the back of the controls and it didn't seem to be working right so I fiddled with it and it started working again. It looked like the valve wasn't sealing when it switched. Anyways I think I am gonna order a new vacuum selector and try that.
