Defrost
Discussion in 'The Garage' started by Blazer1AB, Oct 29, 2005.
  1. Blazer1AB
    Blazer1AB Registered Member
    Sep 1, 2005
    29
    KC
    I had to put a heater core in my blazer last weekend and ever since, the defroster hasn't worked. I havent had a lot of time to check it out, but I have basically found out that the door that is behind the middle floor vents doesn't do anything when i switch the control to defrost. I will inspect the vacuum lines tomorrow, but if those are fine, do you think its the little silver diaphram or is something with the actual door broke? I've reached in there with my hand it its feels like its spring loaded- so is this right?
  2. jeeptuff
    jeeptuff 1/2 ton status
    Aug 22, 2005
    158
    Arlington, WA
    Mine does the same thing, no defrost..
  3. nstarry
    nstarry 1/2 ton status
    Feb 13, 2004
    349
    st.cloud minnesota
    there is a another post on here about this everybody says its a vaccum line but they wont tell you wich one it is yet
  4. jeeptuff
    Aug 22, 2005
    158
    Arlington, WA
    So, which is it?? Come on somebody is holding out on us!!!! :saweet: :1zhelp: :ears:
  5. big d
    big d 1/2 ton status
    Oct 24, 2001
    1,236
    illinois
    im guessin its the lil plastic clip on the door that changes the direction of the fan air.the rod is fastened to it and the clip has a sheat metal screw passing thru it. the clip usually brakes right in the middle. its only like a 1.50 or sumpin like that from a g.m. garage. im gonna go pick myself up a couple here pretty soon and fix mine. hope this helps.
  6. GM Man
    GM Man 1/2 ton status
    Jan 12, 2003
    549
    Denver CO
    I had the same problem on my 78 Jimmy and I found out that if you unplug the vacuum canister on the passenger side firewall, then nothing wants to work. Check this out to see if yours is unplugged.
  7. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    the controls themselves are activated buy vacum , were is the vacum coming from ? I found the vacum line coming out of the fire wall right buy the heater/ air cowl so I could fix it if i had any idea wear to hook it up to :(
  8. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Runs off of a vacuum port off the backside of the intake manifold right between the carb and dist.
  9. nstarry
    Feb 13, 2004
    349
    st.cloud minnesota
    thanks man
  10. anjieandjohn
    anjieandjohn Registered Member
    Oct 31, 2004
    61
    Virginia Beach
    Big d, you got a part number for that little plastic piece? I took all my ducting out today and guess what, I have that little broke plastic piece. Where did you get it from? Thanks.
  11. big d
    Oct 24, 2001
    1,236
    illinois
    i dont have the pn but its only available from the chevy dealership. just tell em what u need. my dealership has 4 and im buyin em all while they r still available. :rolleyes:
  12. anjieandjohn
    Oct 31, 2004
    61
    Virginia Beach
    Went and got that little plastic piece for the door...cost $1.68 with tax....I put one on and now the heat blows like the dickens...with no blow by to the vents. Now, when I switch from heat to vents or defrost, it doesnt switch. Isnt there a vacuum switch in the ducting somewhere?
