Defroster Vent
Discussion in 'The Garage' started by Tannerman, Jan 30, 2006.
  1. Tannerman
    Tannerman Registered Member
    Aug 22, 2005
    13
    Canada
    Hoping someone can help me with this one. I am having a bit of trouble with my heater system. I have good heat but can't get heat to upper defrost. I took apart the lower venting and the door to direct heat up does not open. I can manually open it but it will not on its own. I see that it is operated by a vacuum system but I can't seem to find any trouble with the lines(holes).
    I am thinking maybe a line is off that controls the heater diaphram or the unit is dead. The lines that go to the control levers all seem to be there and functioning. Where does the line to the diaphram go to to get the vacuum? I can't seem to find it without taking the whole darn thing apart. Or, do I need a new one?
  2. AV8
    AV8 Registered Member
    Oct 8, 2005
    45
    Winston Salem, NC
    Mine did the same thing. Turned out to be a disconnected vacuum line under the hood on the pass side IIRC.
  3. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Ya someone shed some light on this problem. seems like a lot of us have this problem. My 90 will blow heat from the dash vents and heater vents or in defrost it will blow from the dash and defrost vents.
  4. Tannerman
    Aug 22, 2005
    13
    Canada
    Thanks for the replies guys. AV8, I'm not sure what the IIRC is. If possible please let me know. I'm going to look for a disconnected line for the heater diaphram into the engine compartment. If anyone has a diagram of the vacuum lines this would be greatly appreciated so it would seem. If I can't find a line through the firewall I'm going to run a line from the intake manifold to see if it works when its open. I presume if it does I'll have to tee it off. I'll post results here if it helps anyone else.
  5. grtwhite
    grtwhite 1/2 ton status
    Aug 3, 2000
    366
    Macungie, PA
    IIRC = If I Remember Correctly
  6. Tannerman
    Aug 22, 2005
    13
    Canada
    I was thinking about this. Are we talking about the
    VRC=Vacuum Recovery Can?
  7. kd7kmp
    kd7kmp Registered Member
    Jun 2, 2004
    99
    Springivlle, Utah
    I had this problem a few months ago. There was a broken vacuum line under the hood near the distributor. Double and triple check ALL vacuum lines under the hood. If one is leaking or broken it will cause the problem you are experiencing.
    Kevin
  8. 86haubs
    86haubs 1/2 ton status
    Nov 14, 2005
    196
    Lemoore, CA
    What is the year and factory setup (eng/trans) your truck came with? I have the vaccum diagrams for a 1980 and up.;)
  9. Tannerman
    Aug 22, 2005
    13
    Canada
    86haubs, the truck is a 1989 350 with a 700 tranny. If you have the vacuum diagram it would be greatly appreciated.
  10. George_Pimpdaddy
    George_Pimpdaddy 1/2 ton status
    Oct 17, 2002
    1,306
    Edmonton Alberta Canada
    i would also like to get that vacum diagram too if possible as i have the same blazer year.
  11. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    Okay when I get home tonight I will post them. All they are is the diagrams from my Chiltons book. Expect to see them around 6:30pm PST.
  12. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    Okay, so I get home and look in my book and the diagrams only go up to '86. I don't know if it is shat you guys are looking for but I went ahead and scanned them to my Webshots, here is the link: http://community.webshots.com/user/indy500ss
    **Warning, these photos are about 2megs each, I had to make them that large so you can read the writing.**
    Let me know if this helps, hope it does. Let me know the fix also, I have a buddy with the same problem.
  13. 86haubs
    Nov 14, 2005
    196
    Lemoore, CA
    So what is the verdict? Did the diagrams help at all? If so what was the fix.
