Degree ring on Benders??
Discussion in 'The Garage' started by Esteban86K5, Apr 17, 2005.
  1. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    Who actually uses theirs?
    I am about to purchase a Pro Tools bender and I am wondering if I should even buy the degree wheel? Those that have a bender do you use it?
    THANKS!!!
  2. highrider_44s
    highrider_44s 1/2 ton status
    Mar 28, 2004
    392
    southern B.C.
    i wish i had a tube bender :frown1:
  3. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i use mine all the time when i bend tube. the only problem is you have to know how much spring back each tube has to get the correct reading. i set the pointer 2* before 0 and bent to 92* and still didn't get a 90* bend. but both bends were the same so that was very helpfull.
    you can always get it later, it will probably cost the same to ship it. mine came in 3 boxes, 1 for the bender, 1 for the die and 1 for the degree ring. i have a pro-tools mb105.
  4. Esteban86K5
    3,712
    Bakersfield, CA
    That's the bender I plan on getting. I just wasn't sure if i NEEDED the degree wheel. Where did you get your bender from?
  5. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i got mine from www.mikegreen4x4.com . i think hes on vaca till may, he was the best price when i was shopping around.
    you don't NEED the degree ring, but it makes it nice for symetrical cage and bumper work.
  6. Nonesuch
    Nonesuch 1/2 ton status
    Jul 16, 2001
    1,467
    Austin(Leander), TX
    The degree ring is helpful but you don't need one. If you are ready to buy, give Greg Youens a call and tell him Justin sent you. He will beat Mikes price for you and he is not on vactaion. www.4wdfactory.com
  7. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    I use the degree ring for every bend. As for spring back I keep the pointer set at zero and read the spring back on every pull. Most of the time it's between 3-4 degrees of spring. You can read it by pulling yourself out of pull and then when you let off to grab the next notch you'll see how much it comes back. This is how many degrees you really have bent. Not sure how most people do it but when the bender is set at zero with all the slack pulled out you can switch from one size tube to the next and the new spring doesn't have to be recalculated.
  8. Esteban86K5
    3,712
    Bakersfield, CA
    WOW!!! He' got some good prices. I'll have to give him a call.
  9. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
  10. tRustyK5
    Jul 23, 2000
    36,170
    1,379
    E-town baby!
    I use the Bend Tech EZ software and a large angle finder I made. I have the degree ring but never use it.
    The angle finder I made is two pieces of aluminum about 24" long with the the ends bolted together snugly. I use a protactor to set my angle finder and then use the angle finder while I'm bending.
    The software is worth every cent IMO, it will pay for itself in saved material on the first project you do.
    Rene
  11. yeild2me
    yeild2me 1/2 ton status
    Jan 7, 2001
    1,309
    fayetteville, nc
    Everything Rene just said here too.....
    I got my JD2 from www.tricktools.com
    Rob
  12. Esteban86K5
    3,712
    Bakersfield, CA
    Yeah i plan on getting the Bendtech from a friend locally. I will be calling tomorrow to all the different places online to see who has the best price on the Protools bender. :D
  13. crazy_cooter56
    crazy_cooter56 Registered Member
    Apr 7, 2005
    6
    Claypool, IN
