degree wheel needed?
Discussion in 'The Garage' started by BranndonC, Oct 5, 2004.
  1. BranndonC
    BranndonC 3/4 ton status
    Mar 18, 2002
    8,591
    Anaheim, Ca
    ok i have my crank/pistons/cam sahft all installed, the number 1 piston is at TDC, the dots sprockets are totally alligned, here is a crude photo chop of how they actually look, but are better alligned in person. so do i need to go out and buy a degreeing wheel, or is it safe to move on to the heads now?
    [​IMG] /forums/images/graemlins/dunno.gif /forums/images/graemlins/thumb.gif
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Looks good to me. I have never had the oppertunity to use a degree wheel.
  3. cybrfire
    Dec 15, 2002
    15,139
    565
    Iowa
    /forums/images/graemlins/waytogo.gif
  4. mudjunkie 82
    mudjunkie 82 1 ton status GMOTM Winner
    Dec 27, 2002
    11,449
    Cleveland Ohio
    unless you are building an all out race motor Degreeing the cam is not needed. The real purpose of it is to check for error on the timing (actual timing compared to the cam card)most cam manufacters will tell you the grinds are real acturate.
  5. dcell152
    dcell152 Registered Member
    Sep 23, 2004
    84
    Nothern Maine
    /forums/images/graemlins/waytogo.gif Looks good run it /forums/images/graemlins/smile.gif
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Looks good. But that timing chain looks thin on the left side and looks like your crank gear is coming apart on the right!!! /forums/images/graemlins/wink.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/thumb.gif j/k I know its a chop...... /forums/images/graemlins/woot.gif
    I've never used a degree wheel either. Just the dot method.
  7. BranndonC
    Mar 18, 2002
    8,591
    Anaheim, Ca
    thanks everyone, now i can continue on the motor /forums/images/graemlins/woot.gif
  8. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    Your good to go. Cam grinding has come along way over the years. If you put it in "straight up" the lobe centers will be right on. Degree wheels are mostly used for indexing a cam with concentric bushings around the sprocket bolts to achieve desired results in a certain rpm range.
