Delay wipers non functional
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tch777, Oct 7, 2003.
  1. tch777
    tch777 1/2 ton status
    Jan 15, 2003
    244
    Colorado Springs, CO
    Yep I turn on the wipers for delay wiping and they just trun on and run like there are no delays, and then won't turn of unless I turn it to the mist setting. We replaced the module under the steering column and that didn't fix it. So that leaves the motor or the mulifuction switch. Where would you put your money on the switch?
    Tim
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    Mine did the same thing. It pissed me off to no end. After searchin on here and asking someone told me to adjust the bolt that comes out of the top left of the motor. I just fiddled with it and for now it works alright. The wipers are real slow though so I might just replace the motor anyway. But yeah give that a try.
  3. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    My wipers do the same thing. I also have ghost wipers every once in a while. Right now my motor is so weak that the blade only go half way and get stuck grrrrrrrr then I have to stick my hand out and fix or shoestring it /forums/images/graemlins/angryfire.gif
    Do a search on it supposedly our wipers have some pretty bad electric problems especially if you have a tilt steering wheel. It pinches some of the wires in the steering column
  4. bckinblk
    bckinblk 1/2 ton status
    Jun 12, 2002
    305
    bristol connecticut
    On 87-up trucks there is a little black box under the steering column .Pull off the plastic peices on each side of the column .It kinda looks like a mini stereo amp with a wire harness coming out of it..This is what cured my wiper gremlin .I think it's called the wiper delay servo..good luck......... /forums/images/graemlins/thumb.gif
  5. bckinblk
    Jun 12, 2002
    305
    bristol connecticut
    Ok I just read that you replaced the delay servo..(dooh).......... /forums/images/graemlins/confused.gif
  6. tungsten
    tungsten 1/2 ton status
    Oct 29, 2003
    104
    Nashville, TN
    Sorry to revive a thread from the dead... but my '85 K5 is doing something similar and I can't help but think maybe it is the delay module as well.
    The wipers don't work at all in the delay positions, but they work fine when I turn them to the full "ON" position.
    Does that sound like the delay module to you guys? Is there any way to check it before buying a new one from the dealership ($57) or should I just take a chance and try to return it if that's not the culprit?
  7. dyeager535
    26,979
    If anyone is willing to check this against a truck manual, I'll scan the '88 Camaro delay wiper troubleshooting section, including flow charts. At least 10 pages of just troubleshooting, and mechanics of the system beyond those 10 pages.
  8. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    I replaced the module (and everything else in the steering column) when I tore it apart because I didn't want to have to disassemble the steering column again. The module didn't fix it. It turned out to be the box under the hood.
  9. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    the delay wiper on my 85' just stopped sowking too! Could it be the switch?
  10. Steve_87K5
    Steve_87K5 1/2 ton status
    May 26, 2000
    521
    central NC
    Take the cover off the motor. See the circuit board. It pulls straight out. Resolder the connections (cold solder joints) where the connector for the wiring harness mates with the board.
    Don't remove the red goop.
  11. tungsten
    Oct 29, 2003
    104
    Nashville, TN
    Which of us were you replying to? /forums/images/graemlins/confused.gif
  12. Steve_87K5
    May 26, 2000
    521
    central NC
    I was replying to all the intermittent problems. Ghost operation, no park sometimes, delay not working, no shut off. I had all these symptoms and resoldering did the trick.
