delay wipers??
Discussion in 'The Garage' started by kustom71, Dec 6, 2003.
  1. kustom71
    kustom71 1/2 ton status
    Mar 14, 2003
    117
    NJ
    Anyone ever retro-fitted 73-80 style truck with later(81-87)or any other style delay windshield wiper controls?I hate having them constanly going?? /forums/images/graemlins/truck.gif
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I dought it will work because my 76' C30 has a switch in the dash and my 85' K5 has the delay switch on the turning lever in the steering column. You would probably need a late model steering column and that would open up a whole new can of worms unless you could somehow wire it to work with the early dash switch? /forums/images/graemlins/thinking.gif
  3. 82diesel
    82diesel 1/2 ton status
    Jul 2, 2003
    316
    Stockton, CA
    My 82 Silverado has the delay on the dash so it might be easier to switch them.
  4. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    84 went to column control wipers, 83 is still switch on dash
    if you swap entire cab harness then you could use 79 style delay wipers in a truck with 83-older column
    hope that helps
  5. dyeager535
    26,980
    Somewhere between 73-80, GM changed the wiper switch mounting setup. Say, for instance, you have an '81 delay setup, and a '73 truck. You'd have to cut the gauge bezel (black plastic) to fit it, and I believe the mounting screws are in a different location as well.
    I've seen it done, but the later dash mounted switch looks bad (I mean the dash looks bad) when the black plastic is cut up, as the holes on the earlier bezel have raised edges. IIRC, the later switch when bolted into an earlier cab will sit down and to the right from the stock one.
  6. jwduke
    jwduke 1/2 ton status
    Aug 25, 2001
    721
    Ice Cream Capital of the World, IA.
    How hard is it to switch a newer ('87) one over?
