Delayed steering
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 80blazer, Mar 17, 2001.
  1. 80blazer
    80blazer Registered Member
    Mar 4, 2001
    41
    glendale arizona
    I think this has been beat into the dirt befor and fixed with the steering box brace,but I was wondering I plan on putting a reese slid in hitch mount on the front of my truck would this solve the flexing of the frame at the steering box. Just wondering
    Jeff 80blazer
    Its time to lock them in!
  2. taterblazer
    taterblazer 1/2 ton status
    Feb 2, 2001
    277
    Boise, ID
    Those ORD Braces look like toys to me. I'm planning on doing some mearuring and getting some steel welded in. Boxed frame, triangulation, whatever it takes. Have fun!
  3. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Something else will give long before a good frame (not already cracked) with the ORD brace does. That brace, given the direction of stress and flex, is way more than adequate.
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56
    Coming soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
  4. 80blazer
    Mar 4, 2001
    41
    glendale arizona
    If I connect the frame together with the reese hitch will that solve the problem. Just wondering
    Jeff 80blazer
  5. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Honestly, I'm not sure. The ORD brace actually bolts in with the frame sandwiched between the brace and steering box. I've never seen the hitch but I suspect it bolts to the bottom of the rails which might help but I think that might still let the box crack the frame side. Just a guess though.
    Bad Dog
  6. Toad
    Toad 1/2 ton status
    Mar 15, 2000
    157
    Utah
    I thought my frame was flexing too but my delayed steering was caused by warn draglink ends. I put new ones on and saw no differnce but after about 2 days it was really loose. I just had to wait for the new grease boots to set and then I retightend the nuts. I have almost instant response now.
